Question about HP Compaq Presario V2000 Notebook
Screen help! my screen turns black if i open it more than 45 degrees!! how do i fix it??
    Novelist:
  • 188 Answers
Probably a loose cable from the inverter to the LCD inside the screen bezel. Here are <a rel='nofollow' href="http://www.screentekinc.com/lcd-removal-instructions_en,compaq,diagram1.shtml">disassembly instructions</a>
The inverter is the 2 wire cable at the bottom right. check it for any breaks as well.
Posted on Dec 18, 2007
Dark screen when fully open amilo m1425
There is a loosing in circuit board, you might not be able to fix this problem by your self it needs technical proficiency
May 13, 2012 | Fujitsu Siemens Amilo M1425
My laptop can only be opened at a 45 degree position otherwise the screen is black in the 45 degree position the light and image is perfect.
You may have a faulty video cable that connects the screen to the motherboard or the video cable needs reseating to the motherboard.
Mar 12, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
How to fix a black screen on my dell inspiron 6000 laptop, it loads up then turn back black, i close down the laptop top and open it up again it works for a sec. then turns back black, what shall i do?
There is a cable between the system board and the LCD. It may be loose or it may be bad. If you open the screen partially to a 45 degree angle, does it stay on? If it does, then it is the cable.
Here is the service manual for your laptop:
http://support.dell.com/support/edocs/systems/ins6000/en/index.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 11, 2010 | Computers & Internet
When turning the notebook -- I get a 'black' screen. Is this an easy fix?
It would be helpful to know if the LED indicator lights that you see on boot up and after are acting normally. If so, and you shine a flashlight close to the screen on a 45 degree angle and can see icons or password prompts, etc., then you have narrowed the problem down to the screen and/or the screen inverter. If you have access to an external monitor and can hook up to it with the laptop, that will show quickly if it's just a screen issue. If the display is good on the external monitor, you know the screen is the problem.
Nov 24, 2009 | ASUS Eee 4G Notebook
There is a large black area in the upper left hand corner of the screen
If it is a square box, it is usually a text box. It can be fixed by turning closed captioning off. Either hit the CC button on the remote until off appears. Or go in to the menu find closed captioning or text and turn off. If it is not a defined box, it could be something inside the tv.
Oct 27, 2009 | RCA Scenium D40W20 40" Rear Projection...
The main inner screen of my LG Muziq phone onlylights up wheni have the phone flipped open half way. if i open all teh way teh main inner screen goes black.
i have (had?) the same problem , and i found that the phone wasnt being flipped open all the way, so i would bend it backwards a fracitona of a degree and it would light up. It still sometimes goes black . Seems to me, theres something wrong in the hinge area, as it also makes a clicking noise . I love this phone, but i had to get it repaired once, and im not doing it again. Also laying it flat on a desk by the keypad, then banging the display backwards works :D . Just fiddle with the display portion, and you'll get the hang of it .
Sep 01, 2009 | Cell Phones
DELL VOSTRO Display goes blank after it is more(than halfway open
You should be able to remove the LCD hingecover and reeseat the video cable. But hte issue may be a damaged cable going thru the hinge assembly which would require a replacement LCD.http://support.dell.com/support/edocs/systems/vos1500/en/sm/display.htm#wp1179838
Jun 04, 2009 | Dell Vostro 1500 Notebook
Hp pavillion f1903
It has a bad capaitors in it open it up look for bulged capacitors replace all bad ones and it will run again i fixed more hps with this problem than any other and it doesn't cost much to fix its under $10.00 thank you have a nice day
Jan 12, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Laptop screen problem
Sounds like a loose connection, you will have to get the repair manual and try to fix it yourself if u don't want to take it to a shop.
May 28, 2008 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
