Question about Linksys Wireless-G WRT54GS Router (e125894)
Error 322 instaling a WRT54GS V7.2 linksys router
I am trying to install a WRT54GS V7.2 router but I keep getting an Error 322 message. I am using an HP Pavilion P6112p PC and running from a Verizon DSL Internet. I have tried all the cable combinations without success. Please help before I break my router!
I have internet access connecting the modem through the router to my PC.
"New Router or Gateway not detected" is the message I get.
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Sep 29, 2009
    Sergeant:
    Champion:
  • 289 Answers
Plug the modems "computer" ethernet cable into the routers "internet" port then plug your computer into the router on the number 1.
Goto linksys.com and download some firmware that is the one for your model number and update your router with it.
(to get in your router type 192.168.1.1) when your connected to it then go administration, factory defaults, then go to firmware upgrade.
Posted on Sep 27, 2009
How to fix error 322 on linksys wag120n
getting ip starting 169.x.x.x ... cannot access router config page. Even reset don't work
Dec 03, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Error 322
Are you trying to run the CD that comes with the router?
I think you can try to setup your router manually instead of running CD. WRT160N router has issues with the firmware so I will suggest you to upgrade the firmware of WRT160n router first.
See how to setup Linksys WRT160N router
Jan 08, 2012 | Linksys WRT160N Wireless Router
I am trying to install a WRT54GS Linksys wireless router, on my desktop, but when I get to step 4 on the CD, it says "waiting for router", but after five or so minutes, an error shows up saying ERROR 322. ...
It's possible.. try using LinkSys "Live Chat" if the online help or CD is not getting the job done for you. The support people there should be able to quickly identify the cause of the 322 error.
LinkSys used to have 24/7 telephone support, but that is gone. The Live Chat is the closest thing you're going to get to that.
Sep 08, 2010 | Linksys Wireless-G WRT54GS Router...
Error code 322 cannot find router, after following installation intstructions.
Try manually entering your setup information (login) for your router and see what happens. Don't use the auto configuration wizard..
May 12, 2009 | Linksys Wireless-G Broadband Router
Wireless router not communicating with computer
Dont run the CD. Connect the Wildblue to your router via the INTERNET PORT then your computer to ports 1 2 3 or 4. Turn off the router wait 10 seconds then turn it back on and restart your computer. you should be online. you dont need to install the router using the CD.
Dec 26, 2008 | Linksys Wireless-G WRT54G Router
Software won't install, keeps getting a #322 error.
Hi -
Reset you Linksys to factory default,
press and hold the reset button for a few seconds, at the rear.
Then, connect via a cable (NOT WIRELESS, use your perent computer) and set your security again.
Remember admin password :-)
then set the security on your other computer with the same as the router
Then, I recommend downloading the latest firmware and install that.
Download the latest firmware from here:
http://www.linksys.com/servlet/Satellite?c=L_Download_C2&childpagename=US%2FLayout&cid=1115417109974&packedargs=sku%3D1121874580098&pagename=Linksys%2FCommon%2FVisitorWrapper
Need additional help write a comment, and I´ll be back :-)
Other vice, vote "FixYa" if this was sufficient.
/Teis
Nov 26, 2008 | Linksys Wireless-G WRT54GS Router...
WRT54GS V6
leave the wireless router settings unsecured then place the range expander as near as possible to the router. press autoconfig buttons and observe the lights...
Jan 12, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54GS Router (e125894) Logo
1,090 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
