Question about Poulan Garden
An i find pictures of a carberator for a crafstman
Can i find pictures of a carberator for a crafstman 2.6 chainsaw so i can see how to put carb back togather
    President:
  • 2,220 Answers
Your saw is made by Poulan.
The IPL (exploded parts list) for your saw contains a breakdown of the carburetor. Until 09/24/09 you could go find an IPL here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Now you must be a dealer to utilize the only known source of parts for your saw. Please register your displeasure with this arrangement here:
http://www.poulanpro.com/node4033.aspx
They should also provide a link to the correct IPL for your saw. HTH
Lou
Posted on Sep 28, 2009
I picked up a Crafstman chainsaw mod 316.350840. Its all in peices which is not a problem except for the carb. it has 3 fuel line ports. what is the 3rd one for?
fuel return line back to the tank
if it has a primer bulb , one line will go there , one for the suction line for the diaphragm and the return line for excess fuel back to the tank to prevent flooding
go google and down load the pdf version of the workshop manual
Sep 25, 2016 | Garden
Replaced manifold on my 201T stihl chainsaw. How do I get the triggers to the carb?
You can probably see how to do this on you tube sir.
Sep 28, 2014 | Garden
Replaced carberator on my 12 hp crafstman, still runs rough
the choke should open on its own if its not then theres a problem with the tention spring or you can try resetting the fuel to air mixture screw on carb but i dont think thats it i believe it to be the choke getting stuck
Jan 28, 2013 | Garden
How to adjust carberator
Some Husqvarna carbs require a special screwdriver to adjust them, some just use a mall flat head tuning screwriver.
Screw both H and L screws in. Then turn them out anticlockwise the following amounts to return them to standard.
H 3/4of a turn L1 full turn (Chainsaws)
Some equipment like blowers and strimmers are:-
H 2 1/4 turns out L 2 1/4 turns out
Nov 03, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What makes my stihl 026 hard to start.had carberator rebuilt two times that didn't seem to help.
You keep putting new parts in an old carb. Just get a new carb and don't be cheap. Your saw will run like new for 40-50 bucks.
Jan 14, 2012 | Stihl Garden
32cc crafstman weedwhacker (2 yrs old)flooding wont start
Nope, it's not the carb. The plug is wet and probably black as well. Wet plug and lots of smoke means too much oil in the mix which is where the problem lies. Get a compression tester and look at the pressure reading; anything less than 90psi means the piston ring is stuck and needs to be replaced/cleaned.
Oct 07, 2009 | Garden
I have a 3516 chain saw mod22-600035-18 Mcculloch the fuel lines
I wish I could help. There are no parts available, there are no Exploded parts lists I've found a link to. These are Chinese chainsaws with the McCulloch name. They ARE Chinese chainsaws and I'm disappointed in Mac. Most mechanics won't touch them. We can provide no more help with this saw. Sorry
Lou
Poulan or Craftsman gasoline chainsaws are reasonably inexpensive, parts are available, and given a little TLC perform well.
Jun 10, 2009 | McCulloch Garden
Crafstman chainsaw at full power when started
If you had this apart, a few things may have happened. First the linkage from carb to throttle trigger maybe jammed between plastic housing or linkage may have come apart and throttle is in the full open position. You'll have to take this apart again and follow the linkage between carb and throttle trigger to ensure all is connected and moving freely and properly. Use care when putting housing back together.
May 10, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Wire is on the botom of the motor and i dont konw what is is
Hi
Remove the fan housing.There you can see the coil.Follow those wires(2) towards the on/off switch.Replace that wire with a new one and start the engine.
best regards savumihai71
Feb 12, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
109 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
