Question about Yamaha RX-V800 Receiver
Yamaha rx-v800 turns off
I have it for 5 or more years. It worked great until recently when it turns itself completely. After turning off it won't turn on for some time. Pressing the power button makes click, it gets power, display comes on, and instantly turns off again. After 2-3 or more hrs it turns off when power is pressed, but it can go off, for no reason. Sometimes it might work without problems for days, but it always comes back. I noticed that sometimes when I am operating the DVD remote, LG DVD recorder with resolution upscaling it turns off, like it gets a commands from the DVD remote and turns off, but it turns off also when no one is touching any remote. I live in a single house, so getting some other remote signal, is not very possible. Even if that's the case, why it won't turn on after it goes off? It always needs some time to readjust.
Thanks for your time.
Any response is appreciated.
    President:
  • Yamaha Master
  • 1,114 Answers
Sounds like your receiver has a cold solder joint on the power board at a transistor or capacitor. Not a major repair, however, it will probably run $100 or so to pull it apart, hunt it down and fix the problem. Not sure of your problem with the DVDR. Do you have a "line conditioning, surge protection" unit? Not a Power strip or low end monster surge. Panamax, APC, Furman, make line conditioning surge units that keep your power steady and will shut down in case of voltage fluctuation in both directions. They cost from 200 to 2000 depending on the equipment you are protecting. It is a necessary component to any system. Hope this helps.
Posted on Sep 27, 2009
Won't turn on
I found that mine works great if I do not over tighten the cap on the battery. back it off little by little until it does work.
Nov 24, 2011 | Leupold RX-III Rangefinder
Hello, I have a 5 year old 47" projection tv that has worked perfectly until recently. It was running fine one night and I turned it off for the night. The next night when I turned it on, there were...
laskey66,
You have a bad convergence circuit. You will need to replace the convergence ICs minimum and could have a problem with the digital convergence box. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, where to get the parts at the best price and how to complete the repair.
Thanks for using FixYa and for the great rating.
hardrocko
Oct 06, 2010 | Hitachi Televison & Video
Completely Wacky 'Sansa e260'
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. That will be the only way
Sep 30, 2009 | SanDisk Sansa e260 MP3 Player
DLP TV Problem
hi, this is heat related and you will need to replace th enclosure fan in this unit. this will fix your heat issue. the fan has failed.
CLICK HERE TO PURCHASE YOUR NEW FAN
May 21, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Turns itself off every time I try to take a photo
I had a similar problem with my Cyber-shot S600. It just turned off every time I tried to take a photo. I bought a Sony recharger + batteries and it fixed the problem. Camera works fine and I'm impressed with the how long the batteries last between charges.
Jan 04, 2009 | Sony Cybershot S650 Digital Camera
Intermittent turning itself off
check your setup menu and make sure that turn off timer is off
here is instruction below on your tv
hope it works
panasonic.com.au/content/library/files/F000518.pdf
Oct 27, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Yamaha RX-V800 Receiver Logo
410 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
