Question about Kenmore Elite 45986 Front Load Washer
My washer is flashing and F what does theis mean?
  • 15,935 Answers
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes:
* Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
begin troubleshooting right at the motor. Why start there? Because the motor is one of the prime suspects and it's easy to check. Remove the back panel and unwind the belt from the drum pulley. Now turn the motor pulley (sans belt) by hand. If it doesn't turn smoothly and easily, you have a bad motor.
If the motor pulley turns smoothly and easily by hand, next step is to run the motor with the belt still removed from the motor pulley. If the motor seems to run fine that way, put the belt back on and run it again. If the motor won't run under load (with the belt on), then that's another sign that the motor is bad.
Suppose the motor turns easily and freely by hand but won't run either with or without the belt. This is a more subtle condition because we're probably dealing with a bad MCU or flakey wire harness somewhere between the motor and MCU, or between the MCU and the CCU.
One trick that often works at this point is to remove and reinsert all wire connections at the board and motor. This tends to clean the small amount of corrosion that will build up on the connections. After you do this put the machine into a service cycle (see the instructions in the tech sheet found inside the unit or you can ). Part of the service cycle is running the motor at certain set speeds which checks the tach.
If you've removed/reinserted the wire harnesses and still no joy, then usually the problem is the MCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
What does error E90 mean?
E90 =cycle blocked suggest check pump/drain etc for any blockage and if you need more on this I will post this link for you to check on these. http://www.washerhelp.co.uk/washing-machine-parts/pumps.html#cl_q6 If this is helpful, a vote with the thumbs up would be greatly appreciated for the free advice and if you need more on thei feel free to get back to me. Thanks
Aug 22, 2011 | Zanussi WJS1265W Front Load Washer/Dryer
My ups thermal printer zebra lp 2844 wont print labels properly
press button until flash 7 times to calibrate, turn off, tur on again if pressist, check the setings from the driver, if thei correct. ajust if necessery.
Jul 05, 2010 | Zebra LP 2844 Thermal Printer
My washer stopped spinning and is flashing a code F what does that mean
try to lessen the load and use it again, se if still flashing the F sign..on other brand and model, this means FULL
Nov 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
No manual how to use thei machine
Try this website may be helpful to you in finding the Manual:
Hotpoint Front Load Washer
Best of Luck Scott
Jan 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Front load GE washer
you just push the delay button once and the light will go off.
Oct 17, 2008 | GE WSXH208A Front Load Washer
PERFORMA WASHING MACHINE
To fit drain hose on WMA range of washers you need to remove the lower rear back panel. At the right hand is the pump, this is where the hose connects to
Oct 06, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washer wont rinse completely. some water remains in the washer.
The pump will be blocked, there is a kick plate at the front of the machine at the bottom, remove this then release the round filter, remove any debris, if theis doesn't work you will have to rvove the pipes/hoses from the pump to remove any debris, had same problem just done mine working fine now
May 15, 2008 | GE Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
20 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
