Question about Frigidaire ATF6000ES Front Load Washer
I get an Error 20 message on my Fridgiaire front loaing washer.
Anyone know how to fix it? It seems like it's not draining.
    Genius:
  • Frigidaire Master
  • 1,474 Answers
Not sure of error message try clearing the pump or filter
Posted on Sep 27, 2009
My washer stops &and F-20 appears on viewer. Whats wrong with my washer
water problem check screens in hoses and valves !! rrors F1, F11 and F20
  • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Apr 26, 2013 | Kenmore Washing Machines
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Lavadora maytag mlg 2000 aww la inicio en lavar esta lllenando a los 20 segundos se apaga , la pongo a exprimir tira el agua pero a loa 20 segundos se apaga doy gracias
hola por que cuando encho ropa a la lavora y le pongo el ciclo adecuado y a los 20 min o segundos me aparece un error f20 mi lavadora es maytag frontal ke puedo hacer????????
Jan 12, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
Hi, I got a Fridgiaire front load washer. I got an error code E 41. Machhine won't start at all. Replaced the board. Now water enters machine for 15 seconds then stops will not spin
The E41 error means the control thinks the door is open. From your description of the problem the most likely problem here is a bad door switch assembly.
Oct 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Jul 07, 2007 | Kenmore 46462 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
145 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
