Question about Kenmore Washing Machines
HF Alarm Getteng HF or FH alarm on Kenmore HE3 washer that is stopping washing cycle. Water flow is fine. What else can we check?
  • 15,935 Answers
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It’s a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Kenmore Elite HE3 does not work with Pure Wash system
One of the things to try is get a Y connector for the machine. Hook both ends of the Y to the washer at the hot and cold, then connect the last part to the pure wash. The HF error is HOT FLOW so it is not seeing any hot water pressure. The actual temperature should not be an issue. Also if you have too much water pressure you wont see the bubbles. If that happens just start turning down the cold water valve on the connection to the pure water unit until you see bubbles in the viewing window. I ams sceptical about these machines because you have to reduce the surface tension of water in order for it to clean, that is partly the job of heated water and laundry soap. Also if there is an ozone generator in that unit, there is a consumable part because ozone needs electrolysis to be generated. I cant help but wonder where the hydrogen goes when it is generated.
Feb 26, 2014 | Kenmore Elite Washing Machines
Fh showing on my kenmore washer
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Inlet valves can be purchased thru the net and fitted by you easily.
Feb 27, 2013 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite He3. It won't complete any wash cycle without stopping and displaying HF. I can restart it but it continues restarts the wash cycle again. Therefore a Heavy Duty wash cycle of...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 31, 2011 | Kenmore HE2 Plus Front Load Washer
My kenmore elite quite pak 2, HE3 shows F then H and quits the cycle.
The FH error code mean that no water was detected entering the machine.The things to check are,a pinched or kinked water hose into the washer, the faucets off or if faucets on make sure that something has not restricted the water flow through the hoses..this will be possible espically if they washer is connected using "AQUA FLOW FLOOD STOP" ..the internal flood stopper will cause water flow to be cutoff for no reason. Also check the filter screens on the back of the washer where the fill hoses connect to,for debris in the screens.
If all above checks ok i would suspect the part called the FLOWMETER was defective in the washing machine.
GENE
Aug 28, 2011 | Kenmore 42822 Front Load Washer
Code F1, does not stop filling, water pours out of soap tray
Are you sure it's not an F/H error?
The F/H code means the unit isn't detecting water fill at the flowmeter. The flowmeter sits just in front of the inlet valve and is attached via a hose, and off to the left of the CCU. Part link to the flow meter==> http://www.repairclinic.com/PartDetail/Flowmeter/1381535?modelNumber=GHW9250MW2
If your washer is filling ok, check the wiring from the flow meter to the control board; I've seen this harness jiggle loose and cause problems.
Read more: Whirlpool Duet / Kenmore HE3/4 Washer: F11 and FH Fault Codes ' Washer Repair ' Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2006/04/09/whirlpool-duet-kenmore-he34-washer-f11-and-fh-fault-codes/#ixzz1GVNXRInv
Get appliance parts at http://parts.fixitnow.com
Mar 13, 2011 | Washing Machines
Our Kenmore elite HE3 model 11044921 stops between cycles and flashes an F and then flashes a H continuously. have to cancel and run rinse/drain cycle
Hi
Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hose, it may be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Jan 10, 2011 | Kenmore Washing Machines
Fh error on kenmore he washer. Washer stopped mid cycle and would not drain. Pulled filter in lower front and water drained but now when I try to run a cycle no water flows and I get a fh error. I changed...
The following link may give you a bit more advice on how to troubleshoot the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
The problem with this error code is the multiple things that can cause it to be generated. This can often be a bit tricky to troubleshoot. You mentioned you checked the drain pump filter. Keep in mind, if anything had been lodged in the pump impeller for any significant period of time, this could have caused irreparable damge to the pump. If the drain pump is not working, the washer will not begin a wash cycle.
I was going to recommend checking your drain hose placement for a possible siphoning situation, but you stated you had no water coming in. A siphoning situation would allow the washer to attempt to fill, but it will experience problems maintaining the proper water level.
You also mentioned you replaced the water inlet valve. Not to undermine your technical abitlities, but did you install it correctly? Verify your installation again to be sure.
Read through the link provided and look at some of the follow up comments from other users. Although, you say your flowmeter may be good, there seems to be a noted problem with them. One consumer explained to me once to make sure the flowmeter is vertical. If it is horizontal, this can also cause problems. I don't know how true that is, but its worth a try.
Another thing to consider are clogged screens in the water inlet hoses. This could be restricting your water flow. Comments from Andrewgrhogg are especially helpful on how to troubleshoot a possible water inlet valve problem.
I hope I've given you enough the go by. Let me know if you still need assistance.
Jun 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Stops about half way thru cycle anf error code HF appears
F/H No water detected entering machine or Pressure switch trip not detected.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
HF alarm
1st ck all hoses and screens for blockage be sure you have good water flow to washer next remove top ck flow meter left side 2 small hoses 1 in one out may be able to tap it on the side and temporaily correct problem best bet is to replace it
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite
hi,
Or
hope this helps.....
Aug 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
59 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
