Question about Maytag Refrigerators
Model maytag pbf2255hew freezer and refrigerator not cooling compresor on and off every 3minutes
  • Maytag Master
  • 1,606 Answers
Pull the refrig out , and remove the rear panel . Is the fan cooling the compressor working ? If not ,replace the fan motor . If it is working , I would say the overload/relay is bad . Pt # 67005560 . This is the piece plugged onto the side of the compressor , with 2 or 3 wires going to it . Easily replaceable and not at all expensive , if you change it yourself .
Posted on Sep 27, 2009
  • 5 Answers
SOURCE: coils freezing up on my maytag msd2656dew refrigerator
Replace the thermostat...I had the same problem...I checked the fan, defrost heater and Adaptive Frost control and could not find anything wrong. Replaced the thermostat and the problem went away.
Posted on Dec 11, 2007
mikedurland
  • 481 Answers
SOURCE: maytag refrigerator clicking
it sounds like a bad:
  • ·       start switch (on the side of the compressor) or
  • ·        compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Posted on Jul 06, 2008
  • 19 Answers
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
Posted on Nov 18, 2008
  • 118 Answers
SOURCE: My Maytag Model MFD2560HEW is not getting cool in
check for ice by fan, no defrost or bad fan
Posted on Oct 24, 2009
Testimonial: "Very good information."
bobicehouse
  • 1524 Answers
SOURCE: my refrigerator side has stopped cooling. Freezer
Defrost problem.
Posted on Jun 03, 2010
My refirgerator model number pbf2255hew stop cooling & compressor stop working...tries to come on but won't
Check your fan on the back of refrigerator...Might need replacing..Surly needs cleaning
Dec 08, 2017 | Maytag Refrigerators
My refrigerator has stopped cooling - though my freezer is still cooling just fine. Please help!! Model # is Maytag MFD2561KES
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 01, 2010 | Maytag MFD2561KES Stainless Steel Bottom...
Maytag mbf254h compresor will not shut off
You need to replace the compresor relay, this is the problem
May 15, 2010 | Maytag MBF2254H Bottom Freezer...
You need to replace the compresor relay this is the one that is stuck.
Mar 28, 2010 | Maytag MBF2254H Bottom Freezer...
Freezer portion doesn't freeze.
check settings. if good check if compresor is running. a relay on compresor could fail
Feb 10, 2010 | Maytag Admiral Top-Freezer Refrigerator
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
Jul 18, 2009 | Frigidaire FRS23R4A Side by Side...
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
Refrigerators Logo
366 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
