Question about Jenoptik JD C Digital Camera
I take one shot and the camera keePS TAKING SHOTSwhich do not come out and battery life is poor
Battery life is too short.
its old or defected
buy a new one
try those chineese websites
buy more than 1
Apr 21, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony Cyber-shot DSC-H7 Battery Life is Only Hours Now
Can you verify that your charger accessory is working correctly?
Jan 06, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Tip
What a poor performance,i hadnt thought the the battery life is so silly,i went...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Oct 13, 2008 | Samsung Digimax D53 Digital Camera
Tip
Short battery life with AAs or camera won't even power up on new batteries?
on Nov 09, 2007 | Samsung Digimax D53 Digital Camera
Camera keeps shutting off.
Please use Sony Cyber-shot batteries for DSC-H2 model camera.
Nov 18, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Battery Problem
If you have used this camera more than three months Try changing the battery. Before using fully charge the battery. Let the battery consumed in your camera fully then you charge again. Otherwise the battery life will reduce. Try this option before trying any other option.
Best Regards
Rafique
Mar 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Battery Life
Your SD memory expansion card may be damaged.
Try the same procedure without the expansion SD card.
Use the Casio QV-R40 10meg memory with same camera settings.
Dec 16, 2007 | Casio QV-R40 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Extend the life of my batteries
Using the flash and LCD monitor affects the rate at which the batteries will drain. The rate at which pictures are taken will also affect battery life. When taking pictures sequentially the battery does not have as much time to recover between each shot. To help to extend the life of your battery, the flash, LCD monitor, and sequential shooting should only be used only as necessary.
Aug 31, 2005 | Olympus Camedia D-395 Digital Camera
Battery life expectancy
The battery life on alkaline batteries vary according to manufacturer and power rating. Alkaline Batteries can provide up to 100 shots with typical usage. The Olympus CR-V3 long-life lithium batteries (LB-01) will provide approximately 500 shots. The Olympus Ni-MH batteries (B-01 4PE) would provide approximately 250 shots per charge and they can be recharged 300 to 500 times.
Jenoptik JD C Digital Camera Logo
14 people viewed this question
Top Jenoptik Cameras Experts
Are you a Jenoptik Camera Expert? Answer questions, earn points and help others
