Question about Canon PIXMA MP780 All-In-One InkJet Printer
Printer will not print out continuously when ask to print mutiple copies.
Continuous jam paper feed cl3500n
I THINK THE NUMBERS BUTTON HAD PROBLEM, TRY TO CHANGE THE NUMBERS BOARD & SEE IF THE PATTERN STILL PERSIST. IF THE PATTERN PERSIST ALTHOUGH YOU INSERTED NEW NUMBER BOARD, THEN YOU HAS TO GO IN SP MODE TO CHANGE PRINT SETTING
Sep 26, 2013 | Ricoh Aficio SP-C210SF Printer
My HP C6380 won't print multiple copies of a page even though I select how many copies I want of the page . I have to keep printing each page individually which is very time consuming.
what is he OS ?........what connection USB/wireless ?..........From what application you are printing? ..........have you checked the printer printing properties and ticked of the collate check box where you have selected mutiple pages ?.....
Jul 15, 2010 | HP Photosmart C6380 All-In-One InkJet...
Hp 4345 scan to folder too light
Making multiple copies from one original thru DH, all copies come out good. Having one original and making mutiple copies, first copy comes out find and the rest comes out light. This is cause by the circut board on the optical assembly. Part # IR4041K121NI
Apr 07, 2010 | HP LaserJet 4345mfp Printer
When selecting a printing task,If I ask for one copy,the machine continues to print even after hitting the cancel printing. Second*lets say there are two pages to be printed the first oage will print,the...
Hello. Try to unplug the printer from the power outlet for about 10-15 seconds to refresh itself. If that doesn't resolve the problem, it might be software communication issue. You can uninstall then reinstall the software. If you're computer is running on Windows, uninstall by going to Start Menu > Programs/All Programs > Lexmark Series folder > Tools/Uninstall. Reboot pc. Reinstall software. If your using Macintosh, go in the Lexmark folder and Uninstall. Reinstall software. Hope this helps.
Mar 17, 2010 | Lexmark C533DN InkJet Printer
HP Photosmart C6350 prints more copies then asked for
How do I turn off the ink level system on my HP all in one C6350 printer?
Jul 15, 2009 | HP Photosmart C6380 All-In-One InkJet...
Epson ACULASER CX11NF we have to replace the PCU every 3 months,
The photoconductor (PCU) is used whenever you print anything. They should last between 10,000 copies (colour) and 20,000 copies (black only), so roughly 15,000 pages. If yours is going through them quicker it could indicate that there is a problem, try giving Epson Customer support a call and ask for advice.
Mar 25, 2009 | Epson ACULASER CX11NF All-In-One Printer
Can't get Lexmark X5410 to print. Printer is on "Copy Mode"
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Lexmark X5470 All-In-One InkJet Printer
Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Jun 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
Canon IP3300
clean you print que it prints all the pages because the print button was pressed several times so for to empty the print que unplug itwait 30 seconds then restart the printer if you press print more than once all the pages will print when the printer is turned on safety measure
Mar 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
15 people viewed this question
old marine
old marine
