Question about Topeak Joe Blow Ace Floor Pump
I cannot figure out how to attach football inflating needle to Topeak Joe blow sport?
    Scholar:
  • 75 Answers
Older model pumps screw in. Newer models get inserted and then you either push the lever down or pull it up to lock onto the threaded end of the needle
Posted on Nov 12, 2009
Impossible to Pump
If I understand, you are tying to fill a tire with an air pump.
I would start by seeing if the pump works without attaching it to the tire nozzle. Is it easier to push now? I wouldn't expect the pressure gauge to go up at this test, as there will be no pressure built up. If you are still having trouble, the pump might be malfunctioning or blocked by something.
If all works well, make sure you push the hose adapter firmly on the tire stem to open the air flow, using any locking mechanism to secure it down. It can be tricky to get this on correctly.
Apr 26, 2014 | Topeak Joe Blow Sport Pump
Guage needle fell off joe blow pro pump
Had the same thing happen. It turns out you can pry off the plastic ring around the dial, then remove the clear plastic window. I did that and just stuck the needle back on at 0.
Oct 13, 2013 | Topeak Joe Blow Ace Floor Pump
Which side do I use for a presta valve? How do I close it; yellow lever at a right angle or parallel?
The Side for a presta valve doesn't have what appears to be a pin inside. The schrader side has the pin. Just try putting it on a valve and pumping. If there isn't an air tight fit it means you need to move the leaver to the other position.
Jul 14, 2011 | Topeak Joe Blow Sport Pump
The pressure gauge on my Topeak Joe Blow Ace floor pump is not working. The pump works fine. How do i take the pump apart and what should I be trying to do to repair?
http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html
  1. Rotate the wheel so the valve is resting just above the floor. Remove the valve cap.
  2. Unscrew the locking nut on the valve stem. Quickly press down the stem to loosen the seal. You should hear air escaping when the stem is pushed in--if you do not, loosen the nut and try again.
  3. Press the pump head onto the valve and flip the locking lever to make a seal. You'll hear air escape, but it should stop after you've locked the lever. If air continues to leak out, remove the pump head and reattach it.
  4. Make two pump strokes and listen for air moving into the tire. If the pump handle becomes hard to press down after only a few strokes, or if the pressure gauge elevates extremely quickly, remove the pump head and repeat Step 3.
  5. Inflate the tire to its recommended pressure. Remove the head by unlocking its lever and quickly pulling it off the valve stem. Secure the valve's locking nut and cap.
Presta Compressor Toolwww.prestaflator.comInflate Road or Mountain Bike Tires Accurately in Seconds!
Read more: How to Inflate a Bicycle Tire With a Presta Valve ' eHow.com http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html#ixzz1Brv5VfAX
Jan 09, 2011 | Topeak Joe Blow Ace Floor Pump
Cannot get my brand new Topeak Joe Blow Sport pump to lock onto a Presta valve. I have locked the lever down, but it does not hold the valve. It is as if the Presta valve is too small for the pump...
They should be designed to fit both styles of valve, but you need to reverse the seal.
you should be able to unscrew the end, remove the sealing rubber and a plastic fitting that pushes on the valve, replace them the opposite way around ,and they will fit the presta.
Aug 22, 2010 | Topeak Joe Blow Sport Pump
Topeak joe blow pumps front but not rear tire
What's different?
http://www.youtube.com/watch?v=Ehf6HL0aLTc
Aug 21, 2010 | Topeak Joe Blow Ace Floor Pump
Punctured inner bladder Tachikara SV-5 volleyball
Fix A Flat. Screw the needle valve into the noozle of a can of Fix a Flat. Squirt enough in to inflate to normal pressure, Roll the ball around to coat the inside. Blow the needle valve clear afterwards attached to a bike pump.
Jan 30, 2010 | Sport & Outdoor - Others
Topeak Joe Blow Ace Floor Pump Logo
581 people viewed this question
Top Topeak Cycling Experts
numbers819
Level 1 Expert
dante
L Pfaff
L Pfaff
Are you a Topeak Cycling Expert? Answer questions, earn points and help others
