Question about Whirlpool GEQ9800L Electric Dryer
Dryer will not run - Whirlpool GEQ9800L Electric Dryer
  • Whirlpool Master
  • 7,482 Answers
Check your electrical breakers.
Check to make sure you have electrical connection and electricity is going to the machine.
Listen closely to see if the motor is running but the drum is not turning, this would indicate a broken drum belt.
Could also be your timer switch,start switch, or motor.
You have to test to find out your problem
Posted on Sep 27, 2009
  • 986 Answers
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer does not stay running. Press the start button and sometimes it starts and sometimes not. Won't stay running. Seems to heat ok. Sometimes displays E9E on the display.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Oct 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My gas dryer starts and will run. However when you let off the start button the dryer stops. If we hold the start button on it will run through it's entire cycle with no problems.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | GE DWSR405GBWW / DWSR405GBCC Gas Dryer
The dryer will run for 5 to 7 min then shut off come back in about 3 min it will run then the dryer will do it over and over again untill it will not trurn on
Dryer Repair ? The dryer will not start
heatman101
Aug 27, 2010 | GE DWSR463EGWW Electric Dryer
I replaced the 3 prong cord with a four prong cord. At first the dryer was running and the drum was not spinning, now the dryer is not running at all.
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} There can be many reasons why your dryer will not start or turn...
heatman101
Aug 15, 2010 | Frigidaire GLWE642AS Electric Commercial...
3 wire plug Maytag dryer, but a 2 wire prung outlet@120 volts.
your dryer can be wired to run on 120 / i would not do / very costley to run . . this is some times done for display on the sales floor . best is to get gas dryer or have 220 wired to dryer .. if in home . **** ..
Dec 07, 2009 | Maytag Atlantis MDE7657BY Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Eastate gas dryer 4-5 years old.
if burner does not reignite and glow bar is lighting up suspect the black coils on valve bad
Oct 24, 2008 | Estate TGDS740JQ Gas Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Whirlpool GEQ9800L Electric Dryer Logo
104 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
