Question about Aiptek A-HD 720P Flash Media Camcorder
LCD monitor is green
The screen on the LCD monitor has a green tint to everything.
  • 3 more comments
  • bobbynich1 Dec 25, 2007
    Green screen on lcd moonitor then it goes away
  • mspenny719 Dec 26, 2007
    Mine has a green screen all the time and I've only used it twice! Too bad I bought it from Circuit City where you have to return it within 2 weeks!
  • gollfnks Dec 28, 2007
    I have the same problem; a green screen. I turned it on and ta-da a green right from the get-go. I have no clue on how to fix this problem.
  • Anonymous Feb 09, 2008
    i have the same problem iwas just using my computer then all suddenly my computer screen all went green and i think i may have kick a wire or something then a few weeks later i just moved my pc screen and it was gone but after a few months later it returned to being green and icant fix it :(
  • Anonymous Mar 30, 2009
    I have the same problem, but when you look at the pics on the computer they are great. this camera has been trouble from the state...should have taken it back from the start
Yeah, same problem here. Mine is less than 2 months old. Maybe a firmware issue (I'm running v1.600- chk your's with MODE + << pressed at the same time), since it seemed to go away by simply closing the screen and then opening again. But could be faulty hardware too, as it appeared now and not before. I'll watch it a while, otherwise will send it back. It's a cheap little sucker.
Posted on Dec 28, 2007
Mine has a green screen too, but sometimes it goes away
Posted on Dec 27, 2007
How can I fix a synmaster b1630 monitor that has green tint on screen now?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 27, 2014 | Samsung SyncMaster Computers & Internet
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
My hp pavillion dv7 1245dx screen has a red tint in the background?
Your lcd screen is bad. It's either the lcd screen or the video card inside the computer, but most likely the screen. You can isolate the problem by connecting an external monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without the read and green tint then your video card inside the computer is good but your lcd screen is bad. If the Borrowed monitor displays the same red and green tint then the video card inside the computer is bad.
It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 05, 2012 | HP Computers & Internet
My screen has gone to a blue tint. What is the life expectancy for a screen?
Blue tint (Red tint, or Green tint) is more likely due to one of the pin on the VGA cable is bent ot the cable is not seated properly of the the video card conectors may be the problem. Try it with another PC and check the pins.
LCD monitors usually fail after about two years due to bad caps.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find
Nov 14, 2010 | Sceptre S1902D 19" LCD Monitor
Green tinted screen
there is a Circle of Colourfull part in the monitor. it is getting break down. need to go service.
thanks to choosing FixYa.
May 28, 2009 | Acer X193W LCD Monitor
Monitor screen changes from regular color to a green tinted screen?
Looks like you need to purchase a new monitor. If it's too worn out then it's the outcome. I also had the same problem before and I ended up buying a new one. You should not experience that thing if it's new.
May 27, 2009 | Dell 1503FP 15" LCD Monitor
Screen has a green tint
The instruction manual should tell you how to get into the menu for the monitor to change the color settingts. With a make and model number I can give you step-by-step instructions on how to change them.
Mar 18, 2009 | Computers & Internet
Screen is now a weird color
The problem might be in the cable. Try to reconnect it to your machine. Also try to set your color settings on the monitor itself, so that all the colors are equal.
Sep 26, 2008 | LG Flatron L1750S 17" LCD Monitor
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
May 31, 2008 | Dell 1503FP 15" LCD Monitor
Aiptek A-HD 720P Flash Media Camcorder Logo
132 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
Michael Galve
Michael Galve
Jose Ma DM.
Jose Ma DM.
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
