When the TV detects an issue (and this one sounds power releated), it will cause the STANDBY light to blink or flash. I would try connecting the TV to an another wall outlet and check if that helps.If the TV is plugged into a Power Strip or Surge Protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV. If this doesn't resolve your issue, I would also try a power reset on the TV to check if that helps to resolve the issue.To Reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power on the TV. This should resolve the issue. - If not, i'd reccomend contacting sony eservice via this link - https://eservice.sony.com/webrma/web/index.do
Hope this helps - good luck!!
We will see, will try everything this evening.
