We just had a problem with our 2 year-old French door LG fridge, after the lights inside wouldn't turn off after the doors are closed. The inside got very warm, and I think if we had not caught this in time, there might have been a fire. This seems to be an on going problem, and LG should come clean and there should be a recall on this before there is a fire, and maybe someone were to die.
We lost a lot of our food, and had to throw out at least $20 worth of stuff. We called the 800 number on the manual, and the man told us it would be fixed for "free," but they are aware of this problem, so what will it take before they just come clean, and do the right thing?
SOURCE: lg french door fridge
do you have mechanical button switch that should close the light if you close the door?... they could be defective. try to look for these button switch that the doors presses as you close them. if they dont have, then they may be using a magnetic door switch which would be very hard to locate and trouble shoot.
SOURCE: Inside top of refrigerator hot light don't turn off.
There is a service bulletin related to this, dealing with deformation / melting of the lamp cover. The fix is to change the lamp wire harness to one that now has a thermal protector incorporated in it (part number 6621JK2003B) along with changing the main PCB board to one that uses a larger relay for this function (part number 6871JB1423N).
In case you want or need to replace the following,
The lamp cover is part number 3110JA1096A and the lamp holder is part number 3034JA1009A
I tried to cut and paste a few photo's, but was unsuccessful. Sorry. Make sure to test that fans and light switches work after part changes.
SOURCE: HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT
EFFECTIVE FROM(SERIAL NO.)
from 704MR***** to 801MR*****
Subject
Lamp Cover Melting Improvement (LG 3D Basic) / 2nd
No.
Loc No.
Before Change
After Change
Note
K-Code
Remark
Part No
DESC./SPEC.
Part No
DESC./SPEC.
501A
6871JK1011A
PCB Assembly,Main /
6871JK1011D
PCB Assembly,Main /
WINNER1 DISPENSER ENERGY STAR '08
C
Change Relay SPEC.
503F
3111JJ1001X
Case Assembly,Display /
WINNER1 BASIC BRAND
ABQ33905315
SOLO PARA SERVICIO, NO PARA PRODUCCION
C
Thermoprotector addition.
503F
ABQ33905304
ABQ33905315
C
409B
6912JK2002C
Lamp,Incandescent /
60W 120VAC 0.40A 480LM - WHITE
6912JK2002E
Lamp,Incandescent /
C
60W to 40W
SOURCE: I have an LG french door fridge and its water flow is very slow
it indicates the problem of a leaky water tube or a jammed ice chute,check it. most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs. please do not forget to rate the solution.thanks
SOURCE: LG LRFD22850SW light won't go out!
if you stay on the line and dont take no for an answer
they just might cover it for you
make sure you mention several times its a fire hazard
and just dont take no for an answer
