Question about GE GSS25SGMBS Side by Side Refrigerator
The ice shoot leaks water into the exterior tray
How did you solve this problem??? The inside of my freezer where the ice tray stands is covered with ice because the ice shoot does not seal. Is there any easy solution?
  • GE Master
  • 1,606 Answers
It sounds like the dispensor flap , is not closing , letting warm air into the freezer . Remove the top cover from the freezer door hinge and disconnect the plug . This removes power to the door . Use a small screwdriver , and pry the bottom of the dispensor display board outward . Remove the 3 plugs . Remove the 4 screws on the white dispensor housing ( 1 on each corner ) and slide the housing out . In the top right , inside the dispensor area , you will see a solenoid with a plunger . These 2 parts usually rust , and have to be replaced . Pt # WR62X10055 . Only 3 screws hold this piece on , so it can easily be replaced .
Posted on Sep 27, 2009
Leaking water from my refrigerator
Tubing in back of refrigerator leading to the ice tray is jammed with solid ice and whence maker timer calls for water back pressure prevents water from reaching the ice maker tray. Remove the tubing from the back and pull out the plastic tube that feeds the ice maker tray. Put the tube in hot water to melt the the and blow through it to make sure itis clear. When reinserting the plastic tube stick your head inside the freezer door and be sure the end of the tube overlaps the tray. The problem will be solved but the same thing will happen at some later date. I believe I solved this problem too. I got a roll of surgical adhesive bandage that's about a sixteenth inch thick and insulated the tube to prevent it from freezing again. It's been two months since and thank God it worked. The Frigidaire engineers could use this one.
Mar 01, 2015 | Frigidaire Professional Series PHS68EJSB...
Ice cube tray does not fill up water feeding tube is frozen.
The problem you are having is caused by water leaking past the=> MJX42111401 Water Inlet Valve Change the MJX42111401 Water Inlet Valve and this will solve the water freezing between ice harvest. On most refrigerators this part can be found on the back of refrigerator and near floor, Let me know if you have other questions, Thanks Sea Breeze
May 24, 2012 | LG LSC27910 (265 cu ft) Side by Side...
Ice builds up in freezer bottom pan, not going down the drain tube. Is this an indicator of the defrost timer not working correctly, and if so where is the drfrost timer on a ETIFTTXKT02 model?
Defrost timer is working or there would not be water/ice in the bottom pan (as you describe it.). Check that the drain tube from the pan to the bottom evaproation tray under the refrigerator is clear of restriction.
Dec 14, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaks from somewhere in the freezer and collects in the bottom where it freezes. How can I make it stop? It gets so thick it leaks out the front and make a puddles on the floor. I have to take a hair...
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
Nov 15, 2009 | Jenn-Air JCD2389G Side by Side...
Water is leaking from top part of freezer down to bottom of inside of the frig. Frost is on the top of the frig in the frigerator.
FIRST STEP: UNPLUG THE REFRIGERATOR. AFTER IT'S UNPLUGGED, DO THE FOLLOWING:
Remove the food from the freezer compartment and place inside the refrigerator temporarily.
Remove the bottom panel and back panel from inside the freezer compartment. You will probably notice that the bottom of the inside of the freezer is covered in ice. Use hot water (not boiling) from the tap and pour it on to the ice that is formed on the inside of the freezer compartment to melt the ice.
CAUTION: DO NOT USE A HEAT GUN TO MELT THE ICE AS IT WILL MELT THE INSIDE OF THE FREEZER COMPARTMENT. ALSO DO NOT CHOP AT THE ICE WITH A SHARP INSTRUMENT OF ANY KIND AS THIS WILL PUNCTURE AND DESTROY THE INSIDE OF THE FREEZER.
If you have a wet vac, you can remove the melted water using the wet vac. Or you can use a towel to mop up the excess water. You will still have to pour hot water onto the ice until all of the ice in the freezer is melted. Patience is key as it takes time to defrost all of this ice.
You will see a drain hole in the back of the freezer compartment that is still clogged with ice. You will need to continue to apply hot water until the ice has completely melted.
Note: When the ice in the drain breaks free, you will see all of the water disappear as it empties out.
In Whirlpool refrigerators, the water runs to a tray underneath the refrigerator. You will hear the water empty out into that tray. Then you will know that you have completely cleared the ice from the drain pipe in the freezer. To double-check this, take a small cup of warm water and dump it into the drain hole and you will see it visibly disappear and run into that tray underneath the refrigerator.
Replace the freezer panels back into the freezer compartment and plug it back in and return your freezer items back in to the freezer and you should be all set.
Oct 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
My fridge has water leaking from the freezer. It
Unplug the power to the Fridge, take the items out of the freezer. There is a bottom tray that's inside the freezer that has 2 or 4 screws, remove the screws that holds the floor to the freezer and lift it out. You will probably see a sheet of ice on the bottom of the freezer. You may have to take off the back cover which is inside the freezer, it covers the evaporator. Then you will want to defrost the ice, do not use a heat gun it will melt the inside of the freezer. Best way to thaw it is leave the power off and melt it with hot water (not boiling). Either wet vac out the water as it melts or use a hand towel to mop it up. Sometimes a turkey baster will work to squeegee it out. There is a drain hole in the back that you will see as the ice begins to melt. That needs to be clear and the only way to clear it is to cover it with hot water. You will know that it clears and working when you see the water drain out thru the drain hole in the back of the inside of the freezer. By the way the drain drains thru a pipe thru a tray that's on top of your compressor. That's what heats it and makes it evaporate. Be advised that as you see that it is clearing, you can stop dumping water down there as some may get on the floor as the pan may overflow and dump water on the floor. If that happens, just mop up the water from the floor. Now put it back together again and plug it back in and you should have no further problems.
Aug 31, 2009 | Frigidaire FRT17G4B Top Freezer...
FRS24ZGE is not making ice had a water leak a while ago so the water was shut off fixed leak and it is not making ice rod for ice tray has been done for a while when the water was shut off door has...
Hi Jeff, Had same problem. Turned out that the fill tube for the ice cube tray had filled with ice. I solved the problem by removing the tube from the back and letting warm water thaw the ice. Reinstalled and it works fine. You may also want to try a blow dryer while still in the freezer, but that may take some time. Good luck, Jim
Jul 28, 2009 | Frigidaire Freezers
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
GE GSS25SGMBS Side by Side Refrigerator Logo
164 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
