Question about HP DeskJet 5550 InkJet Printer
Cartridge lights blink. Replacing, cleaning,
Cartridge lights blink. Replacing, cleaning, on/off did not help.
Print cartridge light is blinking
For the Deskjet 940 open the lid to see which cartridge the printer is compalining about. Clean the carriage and cartridge electrical contacts with a cotton swab moistened with water and verify that that the correct cartridges are installed (45 and 78). Then clean the contacts on the cartridge and the printer, also try these steps here.
Hope this helps, Thanks for using fixya!
Nov 04, 2011 | HP DeskJet 1220c InkJet Printer
Ink light of my tx101 keeps blinking
Hello, Amit.
From FixYa, give this a try:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Hope this helps.
Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
ORANGE LIGHT IS BLINKING AND PRINTER WILL NOT PRINT
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | HP Laser Jet 1320 Printer
Replace ink cart and amber light still blinks
Usually if the Amber light is blinking with a new cartridge, that cartridge has bad electronics.
Try replacing the cartridge with another or the old one, if the light goes out it was just a bad cartridge.
Sep 10, 2009 | HP DeskJet 932c InkJet Printer
Orange blinking light at cartridge icon
The Amber light is designated as the "Ink Error" light. With regards to a 960C Hewlett Packard or almost any inkjet printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Sep 10, 2009 | HP DeskJet 960c InkJet Printer
Both paper and cartrige lights blink & E in coppies won't leave
just replace the cartridges its the cartridge replacement error .or check out in the printer for any paper jam that also gives this E error on the printer.but mostly its the cartridges error.also try cleaning the cartridge before replacing them sometimes the cleaning helps.
Dec 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Error
Dec 13, 2008 | HP DeskJet F380 All-In-One Printer
New cleaning solution cartridge leaked
If you both have the same problem from the same merchandise, than maybe you should just switch razors and Rely on a different company.
Jul 28, 2008 | Braun Syncro 7526 Electric Shaver
Orange cartridge light error keeps on blinking!
clean the carriage home
check the data cable for the carriage home
check the media sensor on the left of the plotter media bar
Mar 12, 2008 | HP DesignJet 450c InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
49 people viewed this question
Seeker5211
Seeker5211
