Question about Fuji FinePix A340 Digital Camera
Battery replacement rechargable battery
    President:
  • 423 Answers
Out of production. Time to make the switch to AA lithiums (Energizer) or AA NI-Mh rechargeables. They won't recharge in the docking cradle, however, so you'll need a charger too.
Posted on Sep 27, 2009
  • 24 Answers
Go to fugifilm .com
Can rechargeable battery be replace and is it economical to do so?
if its rechargeable why replace it just recharge it. depending on what it is in you may be able to find a replaceable regular battery for it, or the rechargeable battery that is in the component maybe bad and won`t take a charge. there fore you should be able to find a battery that is the same. rechargeable batteries do have a life span.
Mar 28, 2015 | Camping, Backpacking & Hiking
Big blue speaker repair
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
If the speaker is under warranty get it replaced.
Taking the speaker apart to replace the battery will compromise or even destroy the acoustic properties of the speakers. Big Blue Live Wireless Bluetooth Speaker
Mar 09, 2015 | Brookstone Big Blue Studio Wireless...
My kindle of two years old battery will only charge to half full, is that normal and can I replace the battery
Places like Batteries + are able to replace some tablet batteries.
Jan 20, 2015 | Amazon Kindle Fire HD
Battery exhausted even after charging.
There are two possibilities. First, rechargeable batteries do not last forever. Take out your rechargeable batteries and replace them with non-rechargeable ones for test purposes. If your camera works ok, it may be that the camera's charger circuit has gone bad. Try charging your batteries on an external charger. If they charge, it is your camera's charger, if they do not hold a charge, it is probably time for new rechargeable batteries.
Sep 11, 2013 | Nikon Coolpix 3200 Digital Camera
Where are the rechargeable batteries located and can any rechargeable battery work as a replacement?
The battery is inside the shaver body. You must remove the rubberized grip to access the screws to disassemble it. You can not use any rechargeable battery. The battery is lithiun ion. The correct battery is available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-liion-barrery-for-pulsonic-model-shavers-p-836.html
Jan 13, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
How to replace battery of wireless laser mouse mi
On the Top on the Mouse u can see the Battery u need to Remove the old Battery's and Replace with New battery see that you use Rechargeable battery because ordinary battery life spam is very less and u need to change the batterys for every 1 month so if u use the rechargeable battery then u need not change battery for 1 month at least for 5 or 6 months the rechargeable battery work and u can keep and spare rechargeable battery when every needed and try to purchase a Sony Rechargeable batterys deepakkumaar.jpg
Dec 14, 2010 | MSI Computers & Internet
I get a green and yellow light on the Ryobi 18v charger and the batteries don't recharge. Does this mean the charger is now bad? Thanks for any help. Dan
This usually indicates that one or more of the rechargeable C batteries is not recharging. The batteries are standard rechargeable C batteries but the terminals are spot welded and are very hard to separate. There are 15 rechargeable C batteries in the Ryobi 18v battery pack. A battery tester will show which battery(s) needs replacing. There are refurbishing centers (Google search) but they will replace all the batteries and usually upgrade the OEM 1500 mah batteries with 2100 mah, or higher, batteries.
Jul 07, 2010 | Ryobi Multi-Volt Battery Charger
2006 dodge durange wont start tried to recharge
Some times battery's are beon recharging that recharge wont do it, after you recharge battery turn your lights on, if very dim or dont come on, battery is no good replace it, also try to start it it if lights go off, replace battery.
Jun 23, 2010 | 2006 Dodge Durango
Honeywell CT200A thermostat battery will not recharge.
Yes the battery charge circuit is burned out, you might as well replace the thermostat, parts will not be made to fix it unless it is still under warranty.
Jan 27, 2009 | Honeywell Programmable Thermostat Heater
Printer will not charge camera batteries. camera screen said to go on line and look for m627-435
Did you go online and look up this troubleshooting tip from HP?  Did you make sure the batteries are rechargeable and in the correct orientation ( + and - )? Here is the results from looking up the error code M627-435 at the HP website:
Solution
  1. Ensure that the batteries are rechargeable. If the batteries are not rechargeable, replace them with rechargeable batteries.
  2. If the batteries are rechargeable, take them out and check for obvious physical damage. If the batteries are damaged, replace the batteries with rechargeable batteries in good physical condition.
  3. If the batteries are in good condition, charge the batteries using the external charger that shipped with the camera before using them in the camera for the first time.
  4. If you have tried each of the steps above and the status message still displays when you try to charge the batteries, replace the batteries.
Cause The Batteries cannot be charged status message is usually caused by one of the following:
  • When first connected to an optional HP AC power adapter or placed on an optional dock, the camera performs a test to determine if the batteries are rechargeable. If the test determines that the batteries are non-rechargeable, an status message displays in the LCD.
  • If the battery charge falls below 1.1 volts, the camera cannot detect that the batteries are rechargeable. The camera does not charge batteries below a 1.1-volt threshold to prevent charging non-rechargeable batteries. Rechargeable batteries discharged below 1.1 volts can be charged in an external charger.
    Apparently, your batteries are either seriously discharged where you need to use an external AC charger to recharge the batteries or their damagaed and need replacing. Hope this helps.
Oct 31, 2008 | HP Cameras
Fuji FinePix A340 Digital Camera Logo
63 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
