Question about NetGear DG834PN Router (DG834PNAU)
My computer has stopped connecting to my netgear dg834pn router even though my mums is still working so it must be my computer. I have lost the disc to install. please help
  • 4 more comments
  • mccaughers Sep 27, 2009
    Sorry should have said I have windows vista. Got to step 2 but no wireless zero configeration appeared, just services or WMI control.
  • mccaughers Sep 28, 2009
    Have already tried that but when I click on network name it says diagnose the problem and when I click on that its says windows cannot solve the problem.
  • mccaughers Oct 04, 2009
    Thanks for all your help buy the problem was what I had feard, have got a virus. It has been taken away to be repaired. Thanks again for your help.
  • mccaughers Dec 08, 2009
    Thanks for your email. I have since got my laptop up and running again, It had a virus, which has since been rectified. Thanks again.
    Mccaughers
  • Amar Sondhi
    Amar Sondhi May 11, 2010
    hello, can you please provide more information, as to, is your computer/laptop connecting vis wireless connection or wired connection? if wireless have tried plugging a wire in directly to see if it works? what operating syste are you using? XP/WIN7/ Vista?? please post back requested so i can troubleshoot the problem. Amar Sondhi
  • Banumathi M
    Banumathi M May 11, 2010
    check whether you are able to online wired?are you unable to scan and connect to the network or only to the internet?Because it might be a browser issue in your computer.Try with different browser and check
  • 1,272 Answers
HI, Follow the steps below to configure your computer for wireless connection:
If your computer has windows XP then perform the steps below:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
For Vista, perform the steps below:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 27, 2009
  • Anand Gupta
    Anand Gupta Sep 28, 2009
    I have already mentioned the steps for visa. Try those steps and letme know the results.
  • Anand Gupta
    Anand Gupta Sep 30, 2009
    Perform the task on vista to manually connect to the network:
    5. Once the list is empty, click on ADD, select the second option MANUALLY CREATE A NETWORK PROFILE.
    6. Type in the network name exactly as you have on the router. (Make sure that you have this name in the exact case as you have on the router).
    7. Select security type here and type in the security key in the box below. Click Next and click close.
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
Jul 12, 2010 | NetGear DG834 Router
My new Laptop uses Windows 7. Will it connect to my DG834PN router?
yes it should work !
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 26, 2010 | NetGear DG834G Router
Once the DG834PN is set up i can get web padges through explorer, but as soon as i start the aol 9.0vr internet connection is lost, HELP
hello, when you say after connecting to AOL 9.0 internet connection is lost, do you mean aol explorer doesn't work, or do you mean IE stops open pages and it was openning before starting AOL? if you close out your AOL does IE then starts working? or tell me what do you have to get it working again?
thank you
Amar Sondhi
Dec 07, 2009 | NetGear DG834PN Router (DG834PNAU)
I lost my router connection due to a virus which lost all my data
instead of using the disc you can set up the router manually.
is there any other computer which is able to go online using this router ?
If you have other computers working then you will not need to set up the router again.
Click Here for more info about the routers
Oct 30, 2009 | NetGear WGR614 Wireless Router
Setting up a wireless lan
The DG834PN is an easy to set-up, single box solution, it plugs straight into your ADSL line – there is no need for a separate modem. Once the DG834PN modem router is connected, configuration is also easy, via NETGEAR’s Smart Wizard™. The Smart Wizard™ automatically detects your ISP’s network settings, and then walks you through each step of the installation process. Or then Call ur ISP.
Thank You,
Your Tech Support,
Fixya.com
Manish Shirsikar
May 18, 2009 | Gigabyte GA-K8NS Motherboard
Connection with netgear to laptop
Helen, you should be able to connect from your laptop to your router wirelessly. From what I understood your router is hooked up to your PC directly. If that's the case from your PC connect to your router and enable wireless. Go to Netgear support web page to find out how to do it. Once enabled, you should see your router's name in the list of available wireless networks on your laptop
Feb 07, 2009 | NetGear DG834 Router
Netgear DG834PN ADSL ROUTER AND HUB - PC dial-up connection
so your trying to use a dsl router as just a router -dsl with dialup?
Aug 06, 2008 | NetGear Computers & Internet
NetGear DG834PN Router (DG834PNAU) Logo
115 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
