Question about Recoton Advent Advent DV1418A 14 in. TV/DVD Combo
Blue screen on my 27" Advent tv/dvd combo
I have had this tv for about 3 years and all of a sudden when it's turned on it shows a bright blue screen with some brighter horizontal lines. You can see a shadow of what is supposed to be on the screen behind the blue. Is this something that could be repaired or should I just chuck it? What shoudl my next step be?
  • wambat5 Mar 23, 2008
    when i turn the tv on there is a blue screen some times it comes on after awhile and works great i can get sound with the blue screen
  • 33 Answers
SOURCE: What type of DVD Recordable Media to Use
You
Posted on Jun 08, 2008
Danmart
  • 291 Answers
SOURCE: Advent model DV1418A
Towersong13;;
the "NO DISC" could mean that the heads are damaged, the disc(disks) [ you did try more then one?] are dirty, not the right DVD format.Even a small finger print,smug can cause problems!
you will have to take the TV\DVD apart to find the problem. I would suggest, buy a simple DVD player and connect it to the back or the [AV] audo\video plugs.
Posted on Jun 09, 2008
SOURCE: advent 27 inch flat screen
i have model dv2020a television and it is locked. i cant unlock my television. i don't have the remote i have a universal remote can u help me.
Posted on Oct 11, 2008
  • 1632 Answers
SOURCE: Advent Tv on direct tv with snow showing on screen
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
gopakumarg43
  • 76016 Answers
SOURCE: advent TS2766A tv has no
Hello
Only one line across the screen is due to total vertical sweep failure. In all CRT tvs have both vertical and horizontal sweeps to spread the picture to the entire screen. If vertical sweep failure occurs, you will see a horizontal line across the screen, and if horizontal sweep failure happens, you will see a vertical line in the middle of the screen or no lines or a dead tv.
In your TV, now the sound will be ok, I thinks so, and posts this solution.
You just open your tv, and locate the vertical output section in the circuit board. It is very easy to findout. Just see the four wires goes from the deflection yoke [the coil fitted at the neck of the picture tube], there will be four of them, out of which two of them will be thick, usually red and blue coloured, and another two of them will be thin. You just follow the two thin wires, which in turn goes to a plug in adaptor and to the circuit board. Just put the circuit board upside down and follow the two tracks undeneath, which will guide you to the vertical output section.
There you can see an IC screwed onto a metal heatsink. That is the vertical output IC. Just check keenly for any loose solderings on the legs of that Ic. It may happen because, this Ic will heat up when the set works. Prolonged times of heating and cooling may make loose solderings or bad solderings. It is very difficult to locate the exact loose point because some of them may have micro type loose contacts, that can't be detected with naked eye.
You just resolder all the legs of that Ic, by applying a little more solder, without shor circuiting the terminals. Chek whether you have rectified the problem or not. If not check the main supply point leg voltage. If there is no voltage follow the track and find out the fault. If there is voltage, check the voltage at the output pin of that Ic. It must be somewhat half to that of its supply voltage. If main voltage is there, and there is no voltage on the output pin, or that voltage is equal to that of supply voltage, the vertical output IC is defective. Resolder it out from the board and go for a same type and number. Replacing it will solve your problem. There is an other rare chance to get the vertical windings in the deflection yoke to open. Bu it isvery rare, out of 1/1000 of it may happen. It can be checked by continuity measuring of that coins winding ends.
You just go with confidence. Take every precautions we take before working with an electrical equipment. Proceed. You can and you will. Take care. OK.
Posted on Nov 18, 2010
Hello, I just purchased a 3-4 year old Sony Bravia HDMI tv and can't figure out how to hookup my 7-8 year old Magnavox vcr/dvd combo player, Help please!
Use the yellow, red, and white inputs on the rear of your Bravia TV. You are trying to use the component inputs.
Oct 13, 2018 | Sony Televison & Video
The foron screen dont show dvd - only show a blue screen. It seem to a conflict in the system as it react very slow Is it possibel to reset the system?
HELP! DVD player/video mode blue screen ONLY! - DVD Talk Forum
forum.dvdtalk.com > DVD Discussions > DVD & Home Theater Gear
Jul 26, 2005 - Windowless vans do NOT have candy, only. When I click on the set up menu, all I see is that blue screen and the green VIDEO in the ...Missing: foron
Help please--DVD/VCR combo blue screen - The Mac Resource Page
forums.macresource.com/read.php?1,653657
Jan 23, 2009 - 19 posts - ‎4 authors
I hope this does not mean that the video channel on the player is ... TV and see where you have the inputs from the DVD/VCR plugged in, if you don't know. .... viewing andonly turn on the JVC when I want to use it for a movie.Missing: foron
Sky HD box just showing blue screen...?! ' AVForums
www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
Feb 03, 2016 | Cars & Trucks
My samsung tv has a bright red screen - I have sound but just a red picture - please help
the problem is in the pcb ner the crt socket.there are three tda6111 ic one for each color(red green blue)try to change the red ic and some resistances there!if you dont have experiance try alocl samsung authorized center!is a routine repair!
Dec 28, 2009 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
We have a blue screen, what do we need to do to get the TV back o
hit the input button on the remote,once or twice to get picture.or it may be labeled audio/video
May 09, 2009 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Blue screen
bad connection but where need tech.
Nov 27, 2008 | JVC AV-27D302 27" TV
Advent 27 inch flat screen
Dec 20, 2007 | Recoton Advent Advent DV1418A 14 in....
TV Dilemma
you have a stuck vhs tape in it.
Oct 20, 2007 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
BASE tv/dvd combo- not toshiba but it looks like this model
Same thing happened with us, the onscreen display button unlocks the tv, goodluck
Apr 03, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Blue green line
I have a tv coby 1360 , now it have a blue screes with red locked. Please help ......What can I do it...
regards
tamara
Jan 15, 2007 | Coby TVDVD2050 20 in. TV/DVD Combo
Recoton Advent Advent DV1418A 14 in. TV/DVD Combo Logo
66 people viewed this question
Top Recoton Advent Televison & Video Experts
Jaime Hernandez
Sheldon Dedek
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
