Question about McCulloch Garden
Mcculloch 110 - loose chain - how do you adjust (tighten) the chain?
    President:
  • 2,220 Answers
Look at the saw body from the nose of the bar, Just to the left of the bar a slotted screw head should be visible (on clutch cover). That is your tension adjustment.
Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the nut that is clamping the guide bar in place (or whatever your saw uses to hold the side plate and bar on with). We don't need these really loose - just finger tight will do.
  3. Ease the tension until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. Now, while holding the nose up, adjust the tension so that the chain just touches the underside of the bar then just a little more.
  6. Continue holding the nose of the bar up & tighten up the clutch cover nut.
Posted on Sep 28, 2009
Replace mcCulloch chainsaw chain tension screw
It will either be in between the two nuts that secure the guide bar OR alongside the engine block right up next to the guide bar and facing forward. You may have to clean the area of debris and impacted sawdust to find it. Clockwise tightens the chain and counterclockwise loosens it. Elevate the tip of the guide bar with the securing nuts LOOSE a bit while making the adjustment then tighten securely AFTER correct tension is attained.
Sep 30, 2014 | McCulloch Garden
Tighten chain
Follow the procedure in your owners/service manual. Otherwise, I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Oct 12, 2013 | Mcculloch 16" Electric Chain Saw Mcc3516f
Mcculloch electramac ems300s chain is loose how to tighten
A link to an OM for a similar model follows:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-MCC1514-6096210915-966993001.pdf
Tension adjustment is on page 10. All chains are adjusted similarly, this one is reasonably complete, the only addition I suggest is to elevate the nose of the bar when adjusting and tightening. Experience tells me adjustments require many fewer tweaks when the nose is elevated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 14, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I have an old mac 110. I believe I need the chain tension adjuster as I am not seeing how to tighten the chain. I can't find my manual so I don't have a part list.
Loosen 2 nuts that are on middle of inside end of bar closest to motor, on retaining plate. Dig out shavings & dirt on outside of that plate there is a recess hole. In it is a adjustment screw to tighten chain. Screw in till it takes up the slack in chain. Retighten 2 nuts when finished.
Jun 30, 2010 | McCulloch Garden
I need to tighten the chain. Is there a way to do
there should be a screw at the back end of the bar.Screw it in to push the bar out ,or forward, thus makeing the chain tighter
Apr 04, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Re-install chain
Chain Adjustment
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They do not need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Look carefully at the picture and your chain, it can be mounted backward; they do not cut when backward.
Dec 04, 2009 | McCulloch Garden
Chainsaw chain will not tighten on the guide bar
The two nuts on the bolts for the chain bar, need to be loosened.
Then the tension screw is tightened by turning it Clockwise. (To the Right)
If the chain doesn't tighten,
1.Insure that the nuts are loose enough, so that the chain bar may slide.
2.Insure that the tension adjusting screw does not have stripped threads, nor the threaded part of the case it screws through.
Oct 17, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Loose chain
find the adjuster on the side cover, with a screwdriver, adjust it to tighten the chain. you must loosen the bolt or bolts on the side cover to do this.
Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
Oct 02, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
125 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
