Which hot key turns the screen orientation sideways?
  • Chip
    Chip May 11, 2010
    Which computer are we talking about??
  • 2,229 Answers
Depends if your computer has this function. Not all laptops do. Read your documentation or go to the computer manufacturer's site and look it up there.
Posted on Sep 27, 2009
My screen is turned sideways
Go to control panel select display, change display settings, then go to the drop down by orientation and select landscape or portrait depending on whether you have your screen turned tall or wide. If tall select portrait, if wide then select landscape.
Jan 07, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
I touched a button on the keyboard that turned the page sideways.. it turned it to the left. how do I turn the page right side up?
Actually you hit a combination of keys. Most likely you hit Ctrl+Alt and an arrow key. Try Ctrl+Alt+the up arrow. If that rotates the screen to upside down, repeat the combination twice more (or use Ctrl+Alt+the down arrow twice).
If that doesn't work, if you have a Windows OS, try the Screen Resolution or Graphics Display settings. Right click on the desktop anyplace with no running programs or icons, select Screen Resolution and then change the drop down for Orientation. This works on my desktops. For my laptop, it's the Graphic Display and then a similar orientation label.
I hope this helps.
Sep 10, 2013 | Logitech Y-RAZ71 Wireless Multimedia...
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Sideway screen INSPIRON mini how do I fix it
Changing the screen orientation of your Windows display can make your screen rotate at a 90-degree, 180-degree and 270-degree angle. By default, Windows operating systems do not come with a built-in mechanism to change the screen's orientation. Certain graphics boards, such as Intel, utilize hot keys to change the screen orientation. If the hot keys do not work on your computer, a program can be installed to create shortcuts that change the screen's orientation. One such program that is Windows compatible is called "iRotate," which is available to download for free.
Turn your computer on and wait for it to load. Once your computer finishes loading, make sure any open programs are minimized or closed. Press and hold the "Ctrl" and "Alt" keys on your keyboard. Press the corresponding arrow key on your keyboard for the direction to which you want to orient your screen. Press and hold the "Ctrl," "Alt" and up directional arrow key to return the screen to its regular orientation. iRotate Application Open the iRotate download site (see Bottom of page.) in your web browser. Click on the blue download link on the left-hand side of the page. The download link contains the text "iRotate" and has an icon of a floppy disc. Save the file to your computer. Open the iRotate file and follow the on-screen prompts to install the program to your computer. You can choose whether or not to put a shortcut on your desktop, place a folder for the program in your "Start" menu or automatically run the program after it finishes installing itself. Right-click on the iRotate icon in your taskbar. The iRotate icon is a blue rectangle that will display information about your graphic properties when you hover your mouse over the icon. Select a screen orientation from the drop-down menu. You can choose a 90-degree, 180-degree or 270-degree rotation. The "Normal Landscape" option returns your screen to its default orientation. iRotate
http://www.entechtaiwan.com/util/irotate.shtm
Mar 01, 2013 | Dell Inspiron Mini 10 Notebook
.. key board not turning sideways to text it did
  1. Double tap the home button on the bottom of the iPhone/iPod Touch.
  2. Scoll left by dragging from left to right at the bottom of the screen.
  3. Tap the button on the bottom left.
  4. Now your screen lock orientation should be turned off so your keyboard will turn sideways when you turn the device.
Mar 22, 2011 | Apple iPhone Smartphone
The screen is turned sideways
It sounds like you accidentally press the key combination to rotate the screen. This is a feature on some video cards to allow portrait display with the right monitor. Your monitor does not rotate so the picture is sideways. To correct this problem simply click CTRL + ALT + Up Arrow and your screen should return to the correct orientation.
I hope this helps, if so please rate our solution.
BuddyMc
Dec 22, 2010 | Dell E173FP 17" LCD Monitor
My lenovo think pad x60's screen has turned sideways. I think I pushed several buttons at the same time by accident. Help!
Typically the hotkeys to rotate the screen are Ctrl+Alt+Direction Key. Ctrl+Alt+Up Arrow should restore your screen to the correct orientation.
Dec 10, 2010 | Computers & Internet
Cant get phone to turn sideways for texting, internet or pictures.
Check under your settings to see if you have the screen orientation option turned off.
-go to Settings > Sound and Display > Orientation
-Orientation should be checked if you want to be able to rotate the screen
Good luck.
Jun 07, 2010 | HTC Hero Smartphone
Acer One screen orientation: How do you change it
Hold down the ALT+CTRL keys, then push the up arrow key to reset the screen to the default orientation.
Jan 12, 2010 | Acer Aspire One PC Notebook
My computer screen orientation changed it is now sideways how do i get it back to normal
When my Screen orientation is Changed upside down I would just press Ctrl+Alt+Up/Down Arrow key. You can try Pressing Ctrl+Alt+Left or Right Arrow Key
Regards
Van
Jan 24, 2009 | Computers & Internet
Computers & Internet Logo
455 people viewed this question
David Payne
David Payne
