Question about Intel Motherboard
I have just installed a Gigabyte MB into a new system. Everything powers up but I get no video signal. Do these motherboards requires a video card?
  • 2 more comments
  • efhoil Sep 27, 2009
    GA-MA785GPM-UD2H
    GA-MA785GPM-UD2H
    How do you know you fried it? Or do you just assume you did?
  • Raul Wilfredo Mesias
    Raul Wilfredo Mesias May 11, 2010
    model of the Mobo please?
    Sergeant:
    Champion:
  • 289 Answers
If it has a video plugin (VGA, or DVI) then no, unless it is fried.
If it doesn't, yes you do.
Posted on Sep 27, 2009
  • Sean Blundy Sep 30, 2009
    well does it include the slots that i asked for?
Can't start DVI interface of motherboard video
It is not your computer that needs drivers, it is the hardware you need to connect to the operating system that needs a driver. From Windows 7 and up, Microsoft only allows drivers, if the manufacturer asked for certification and the hardware and driver work conform Microsofts demands. If the hardware and driver is certified the driver is also on the Microsoft website. Most of the time if you use new hardware the operating system goes to Microsoft to see if there is a correct driver and then installs the driver.
For older hardware, only few manufactures make drivers and ask certification. Most only develop drivers for their new hardware. So for older hardware there are only a few drivers. If Microsoft can't deliver drivers, or the manufacturer from the hardware can't, you are lost. The devices won't work with the new operating system. Nobody told you that before upgrading.
Aug 02, 2014 | Gigabyte GA-B75N -LGA1155 Intel B75...
How do i disable onboard video on a intel d865glc motherboard?
A couple things to try:
  1. Most important, check with Intel's support site to see if you have the latest version of the BIOS.
  2. Boot to the BIOS: Choose "Configuration", then "Video", choose "Enable if Primary" or if you're feeling brave choose to Disable it entirely. WARNING: DON'T do this until your other card is working properly! You've been warned!
  3. While still in BIOS: Choose "Configuration", then "Video", choose "AGP" if available, or "Auto" if AGP is not an option.
Information from Intel support website.
Oct 21, 2012 | Gigabyte GV-N76G256D-RH GeForce 7600GS,...
System wouldn't power up and when i replaced the power supply it now powers up without pushing the power button but does not even enter bios (screen is blank as if no output). Won't spin up or read Windows...
You've probably reset the bios, so we won't belabor the point. Sounds like the motherboard is toast. You replaced the power supply, and that was probably the culprit, but it took out the MB as well.
A 478 board is older, but you should be able to eBay one with similar specs.
http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1863
Jan 08, 2010 | Gigabyte Computers & Internet
No video on new Gigabyte GA-MA770-DS3 motherboard
There are a couple things that you need to look at. The first is your power supply. I've had computers seeming to run fine with no video. Turned out to be bad power supplies.
Does your video card require a power connection? Many high-end video cards need an external power connection. If the card has a power connection, use it.
Have you gone in and checked the cmos settings? What does it say (if anything) for the default video?
Now remove all connections to drives (hard drive and CD and try for video. Try it.
Next, if possible, swap out memory.
After you've tried everything (including maybe burning incense), time to try a new motherboard.
May 27, 2009 | Gigabyte Computers & Internet
No Signal
just out of curiosity confirm that the power switch is set to 115/120 and not 230/240 (assuming you are the states)
Try These please
1- if the motherboard has a built in video card, plug the monitor unto that to test .
2- remove the video card from its slot then reseat it, then power on system
3- remove the memory and reseat, then piower on system
Sep 19, 2008 | Nvidia GeForce 8800 GT 512MB Graphic Card
No signal on monitor
The beeps you heard, 1 long two short is the bios telling you that there is a problem with your video card. Normally you would remove & reseat it. Not the case with the intergrated video. When you added an AGP card you should have been able to get video. All video is controlled by the intergrated video controller. If your sure the radeon works than all that is left is the mb controller which can't be fixed. There is a slim chance you might get a PCI video card to work. Link to your board:
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1766
Jan 13, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Vga
I would try switching slots on the MB. I'd hate to think a new MB has bad slots, but I've seen it happen. You might also want to try the card in another computer that you know is working. If it works there, then you've got an MB problem, if it doesn't then I'd say the video is bad. Bea
Sep 11, 2007 | ASUS P4S8X Motherboard
No any video signal from the video card
When you power on your computer do you hear any system beeps from the PC speaker? When the computer is turned on it will run through a system check and one of the things it checks for is the presence of a working video card. One beep typically means everything checked out ok and your graphics card is working and it will continue to boot. If you are getting past that initial test I would next look at the monitor and see if it can handle the signal that is being sent to it. Are you not getting any of the boot up text display?
May 31, 2007 | Gigabyte ATI RADEON X550 , (256 MB) PCI...
Intel Motherboard Logo
79 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
