Question about Hoover S3765-040 WindTunnel Bagless Canister Vacuum
Won't **** an dlight flashs
Won't **** and light flashs
  • 1 more comment
  • goofeephoto Sep 28, 2009
    how do you clean the pump and where is it thanks
  • goofeephoto Sep 29, 2009
    it si bah less and the hose is fine (unobstructed) I did get it to **** but when on the high setting, the light flashs and the sucsion changes. where it the pump so I can check it?
  • goofeephoto Sep 30, 2009
    There is no clog in the hose but it now sucks but flashes when in the high level and there is a change in the tone(sound)
    President:
  • 1,124 Answers
There could be a clog in the hose or in the unit close to where the hose connects,, or in the metal hose..
Take the hose off and try to look into it..
Or in the unit close to where the hose connects to it..
Posted on Sep 29, 2009
    Top Expert:
  • Hoover Master
  • 76,848 Answers
Is the bag full or the hose obstructed?
  • 3,741 Answers
If the light is flashing and the vacuum cleaner does not start then there are two possibilities you will have to look out for 1)the filters and pump is getting blocked this needs to be properly cleaned.clean the filters and pump then check out again.if the same problem occurs then 2)its the board getting short due to any of the components getting overheated.so the inner board needs replacement.mostly this Hoover internal main boards are non repairable.they needs to be replaced if the board is short. --------------------- you can get the required parts from ---------- http://www.gottahavebags.com/parts/parts_hoover.html ---------------- thanks.this will help.please do rate the solution.thank you for using fixya.keep updated.
Posted on Sep 27, 2009
Neato vacumm won't turn on
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Apr 17, 2013 | Neato Vacuums
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Oct 20, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuum roller won't turn and there's no suctions. Red light Doesn't blink
go to http://www.dyson.com/
get the support and download the model, troubleshooting, video for your trouble.
God bless you
Sep 16, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
Dc17 dyson lights up but won't run
I'm sorry to hear you're having difficulties with your Dyson. If the machine won't run at all, I'd encourage you to give us a call free on 1-866-693-9766 so we can run through some troubleshooting with you - we may be able to resolve the issue right over the phone.
Best wishes,
Jack
Dyson Online Customer Support
Dec 26, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Won't charge. Red light come on for about 5mins then flashs red when i pull the trigger the red light comes on does not turn to green nothing works
Hi Peter,
I'm sorry to hear you're having difficulties with your DC16. From what you've described, it sounds as if the filter may not be correctly fitted - please follow the steps shown in our online support guide to resolve this:
http://www.dyson.co.uk/support/help.asp?article=1519&product=DC16-SY-STD
If you're still having issues after trying this, it's probably best if you get in touch with us directly, so one of our Helpline experts can run through some troubleshooting over the phone. You can call free on 0800 298 0298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Nov 01, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Flashing lights.
The Flashing lights indicate several different things. 1 flashing red light means its time to charge your unit. if it is still flashing after charging then you will more than likely need to change the battery. A flashing red and green light means that the unit is overheating which could happen if the filters need to be washed, or that there is a blockage or if your machine has been left in direct sunlight. Allow 1 hour for machine to cool down. 3 flashing lights indicated that the pre-filter has been put on incorrectly. I hope this helps. If you do decide to wash your filter dont use any type of soap it is not needed and allow fiter to dry for atleast 24 hours. putting a wet or damp filter in will damage your machine.
Sep 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Brush won't turn
There is a good chance the belt is broken. The reason belts break is because the brush seizes up due to hair wrapping around tight at the ends of brush. Inspect closely with a flash light to check for this.
Aug 18, 2011 | Sebo X4 Bagged Upright Vacuum
I have just switched my singer 7463 on and all the lights on the stitch selection are flashing and it won't sew.
Most probably a threading issue. Turn off machine and be sure top transparent path is threaded correctly. Turn machine back on.
May 23, 2011 | Vacuums
Hoover S3765-040 WindTunnel Bagless Canister Vacuum Logo
57 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
