Question about Apple iPod touch
When trying to connect to itunes its telling me its locked with a passcode, must enter passcode but ipod has froze cant do anything
  • 24 Answers
Disconnect ipod n hold down pwr & menu buttons until apple logo appears on ipod screen
Posted on Sep 27, 2009
    President:
  • 392 Answers
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
Warning: you will lose all your data
Posted on Sep 28, 2009
  • anujtaluka
    anujtaluka Sep 29, 2009
    This is the only solution....kindly inform what problem you are getting so that i can analyze what went wrong with the solution.
I forgot the passcode to my iTouch
k ppli just got ma itouch but got it used and it wont let me do anything it only says ipod is disable connect to i tunes and i did wene i go to i tunes it says itunes could not connect to ipod because it is locked with a passcode you must enter your passcode on the ipod before it can be used with itunes so wat could do plz help
Jun 22, 2010 | Apple iPod touch
My apple ipod is disable and said to connect to itunes...
reconnect it and then you have to have itunes disconnect it. Its the stupidest thing I have ever seen.. Once its disconnected you can remove the cable from the pc but not before or it locks up...
Sep 21, 2009 | Apple iPod touch
Refurbished iPod locked
well you can conpleatly restore it by no luging it in and holding the power buton for 3 seconds then with out leting go of the power buton hold the home buton for 10 seconds then let go of the power buton and just hold the home buton for a further 30 seconds.....
after you have done this plug it in to your computer with iTunes allready running and a icon should say unresponcive ipod or somethin along those lines just click RESTORE
hope this helps
dale gough
Aug 12, 2009 | Apple iPod touch
Double Problems...
this problem happens when you try connecting a ipod to a new Itunes. If you know the lock code you can remove it temporarily until you have it connected and authorized for that computer then you can apply a lock code to it again. the lock code can be removed by going to the settings icon then general option and turning off the passcode lock. then plug into your computer and Itunes will start and go and authorize that computer then all should be good.
Aug 05, 2009 | Apple iPod touch
Ipod cant hook up to itunes or turn on
try putting your ipod in DFU mode. after putting your ipod in DFU mode restore it. that will the problem.
Jul 23, 2009 | Apple iPod touch
Ipod touch 16gb, passcode forgotten screen reads disabled.
hope this helps
dale gough
Jul 21, 2009 | Apple iPod touch
My iPod won't let me enter passcode, stuck on connnect to itunes
just connect it and go to my ipod. go there and click on restore. clickl on that and say yes. it will take around 20 mins to restore. hope this helped.
Jul 08, 2009 | Apple iPod touch
My ipod still won't do anything
If you're locked out, the only way back in, is to restore to factory default settings.
Try the following:
Make the iPod Touch go to Recovery Mode
If for some reason your iPod won't connect to iTunes, or whatever reason it is, you might need to make your iPod Touch into Recovery Mode. Here's how you could do that.
Makingyour device in Recovery Mode is irreversible. That means, once youexecute this, you can never get back your home screen until youcomplete the restore. So don't attempt this, because there's no room ifyou suddenly decides to change your mind. This method can also be knownas Manual Reset.
Step 1: Hold down the “Home” button
Step 2: Hold down the “Standby” button
Step 3: When it says “slide to turn off”, ignore it.
Step 4: It should restart with a blank screen. DO NOT LIFT THOSE BUTTONS YET.
Step 5: An “Apple” icon appears. You can lift the “Standby” button, but keep pressing the “Home” button
Step 6:Once you see a “connector” and an “iTunes” image (looks like when youjust bought it), that’s when it’s in Recovery mode. You can lift allthe buttons.
Perform a Manual Restore
Nowyou will need to perform a Manual Restore on it. The term "Manual", asthe name suggests, does not involve in using automated download viaiTunes. Instead, we are using iTunes do perform the Restore on the firmware we want.
See: Download the appropriate firmware
Step 1: Connect the iPod Touch, which is now in Recovery Mode
Step 2: Launch iTunes. iTunes will tell you that the iPod Touch is in Recovery Mode.
Step 3: Hold SHIFT while Left-click on Restore button. A file browser should come up. Select the appropriate firmware, then wait for the restoration to complete.
NOTE
You can also do this Restore if you want to downgrade firmware version 1.1.2 into anything else.
And viola! You should be kicked out of the misery, and start your hacking all over again.
Taken from this website.
Mar 19, 2009 | Apple iPod touch
Apple iPod touch Logo
110 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
