Question about Whirlpool Washing Machines
How do i remove the drum from a whirlpool top loading washing machine? The agitator is out.
    President:
  • 1,937 Answers
Please see the following Whirlpool installation and maintenance manual for Top Load / direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
You have to remove the agitators and the drive block.
The drive block is held on by a spanner nut. Whirlpool and others sell a special spanner wrench but I found that using a short (10") pipe wrench hooked onto one of the spanner nut tabs and giving the wrench a short smack with a hammer will do the trick.
Then using a short block of wood under the drive block carefully tap it up to remove it.
Then un-snap the clips on the Tub Ring and lift it out of the way.
The drum will pull up and out.
Posted on Sep 27, 2009
the dr
  • 447 Answers
SOURCE: whirlpool top load washing machine - agitator
There are gears inside the agitator that are very cheap and relatively easy to change they are called agitator dogs. Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
Posted on Oct 01, 2007
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
jsrock516
  • 5911 Answers
SOURCE: removing agitator
Sometimes small articles of clothing can manage to get between the inner spin basket and outer wash tub. This is NOT common, however. If this were the case the memory stick you mentioned, would end up lodged in the drain pump. There would be a noticeable noise from the impeller hitting it and it may cause the pump to fail, resulting in drainage problems. More than likely, its right where you suspect it is. To remove the agitator, do the following:
1. Remove the center cap or dispenser from the agitator.
2. Under the cap or dispenser is another plastic cap with a pull handle on it. Lift this cap out by pulling straight up, exposing the agitator mounting bolt.
3. Loosen the agitator bolt using a socket and ratchet. Once removed, grasp the entire agitator assembly by the bottom flanges and lift straight up. The entire agitator should come out.
NOTE: When reinstalling the agitator make sure you DO NOT overtighten the mounting bolt or it can cause damage to the agitator and restrict the movement. Good and "snug" is the rule of thumb.
Searspartsdirect.com has an excellent exploded view diagram of your agitator and components if you need a good reference. Just type in your COMPLETE model number and look under the "Agitator, Basket and Tub Parts" heading.
I hope you find what you're looking for and hope this helps you in some way. If you require additional assistance, please let me know.
Posted on Sep 26, 2008
  • 33 Answers
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Posted on Dec 17, 2008
abhishek33
  • 1239 Answers
SOURCE: Whirlpool Washing Machine Won't Agitate
Hi friend...
it is usually caused by anything stucked below tub,if its not then if is actualy timer,,,check them both...
thank u.....
Posted on May 03, 2009
The agitator works well during the wash cycle. When the drum spins, the agitator will not if the clothes touch the agitator. The water empties, but the agitator prevents the drum from spinning.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following Whirlpool Service manuals for top load, direct drive washers. They describe what happens in the transmission when the washer goes into spin mode:
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Also see the Whirlpool Parts list for their Commercial washers, although the consumer models use the same transmission.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Basically whats happening is this.
When the washer goes into spin mode two plastic cams are forced together and raise a gear on the main agitator shaft that is supposed to keep the agitators from spinning. If the cams are worn (not necessarily broken) the gear doesn't lift high enough to completely disengage the agitators. We had the same problem. Ours was a major gear noise but a clicking could also be a symptom as well as the agitator keeping the drum from spinning. A set of Whirlpool Agitate Cams (part number 62580/01) cost about $15.00.
It's a bit messy to fix (15 oz. of 80-90 weight gear oil in the transmission available at auto parts stores) but very inexpensive.
See the following for how to remove the transmission.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You don't have to remove the drum.
You can also see this site for removing the transmission.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
I'd also check the Motor Coupler (a $15.00 item that tends to wear) while you have the transmission out.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Jan 20, 2011 | Kenmore 22422 Top Load Washer
Agitator for whirlpool washing machine
The plastic dogs are stripped inside the center of the agitator. To remove agitator pop off the top center cover(slot for screwdriver) There is a 7/16 inch bolt with standard thread, remove it and pull out agitator. Pull the agitator apart, you can stand on the bottom half and pull on the top, you have to reassemble it with the new dogs replaced(there are four in a package) Fairly simple, no special tools needed,
good luck.
May 27, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine agitator has grease on it & doesn't always turn
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
And the Whirlpool Parts list for these washers:
It sounds as if the Gearcase Cover Seal may be worn and is allowing transmission oil to work it's way up the main agitator shaft.
I'd pull the motor and transmission to check for leaking and probably check all of the seals on the gearcase and drive tube.
(IT SOUNDS LIKE A REAL PAIN BUT ISN'T.) THE PARTS TO REPAIR ANY SEALS ARE INEXPENSIVE.:
For example, the above part number 3349985 is $9.09 at Sears and is a basic Whirlpool part.
See the following for how to release the console and cabinet and how to pull the pump, motor, gearcase and drive tube.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=142
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil.
Check all the seals and replace as necessary.
Also see the following Whirlpool document on the transmission.
Overall, its a lot less expensive to replace a couple of seals than to replace a $170 gearcase.
May 09, 2010 | Kenmore 22422 Top Load Washer
The agitator spins automatically(not the drum)when the power is switched on and stops only when power off in the top loading fully automatic whirlpool washing machine
If you saying that the machine agitates when ever it's plugged in. You will most likely have a bad timer. You will find that the points are welded together inside the timer
Nov 17, 2009 | Whirlpool Washing Machines
Cleaning the drum of the Whirlpool 3 LSR 6233 EQO (get it out)
Remove two screws that hold the control panel,pull forward and lift ,tilt back. Unplug door switch and remove the gold clips that hold the back to the top of washer cabinet. Lean cabinet towards front and remove. Unsnap tub ring at top from outer tub. Remove fabric softener dispenser cup at top of agitator. Remove snapped in plastic cover and seal underneath. Remove bolt under the cover. Remove agitator. Remove spanner nut that holds drum in and remove drum.
May 13, 2009 | Whirlpool LSR6332K Top Load Washer
Top agitator won't spin
Your agitator dogs must be replaced.
With a flat blade screwdriver pry off the top cover on the agitator.
Remove the 7/16 bolt inside.
Pull up on the agitator and remove it.
Purchase the agitator dog kit from the appliance parts store.About $10.00.
Mar 10, 2009 | Whirlpool LSB6200KQ Top Load Washer
Now do you remove agitator from washer drum?
washing machine is not working properly kindly advise who can repair in south delhi in Devli Village, Near Khanpur, New Delhi-110062
Jul 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
168 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
