Question about KitchenAid Architect Series KSRP22FSSS 33" Superba Side-By-Side Refrigerator w/ 21.7 Cu. Ft. Capacit...
My kitchenaid superba ksra25ILss01 freezer works but does not keep food cold in the fridge. It is 7yrs old. Any ideas?
dididsaythat
  • 291 Answers
SOURCE: superba kitchenaid fridge not very cold, freezer is fine
do you have any frost build up it the freezer back wall... fan blowing in freezer and in back ...condeser coils clean... if all the above is ok ...must have temp. sensor or themostate cold control problem
Posted on Sep 02, 2007
  • 1073 Answers
SOURCE: Kitchen Aid Superba side by side
check the relay on the compressor
Posted on May 16, 2008
tborn6
  • 700 Answers
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Posted on Apr 04, 2009
  • 4 Answers
SOURCE: Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
Posted on Apr 24, 2009
Illeagle
  • 525 Answers
SOURCE: KitchenAid Superba fridge section not cooling, freezer is cold.
You have done a good job of attempting to diagnose by process of elimination, but this is a more complex system. I have provided some links below to assist you in diagnosing your problem. Links courtesy of www.repairclinic.com.
1. Ascertain that the evaporator fan is operational. This may be controlled by the Door Switch, (No.4) and could cause the fan to be inoperable.
2. Ascertain that the Fresh Food compartment light goes off when door is closed.
3. The air diffuser may be faulty by not controlling the air flow from the freezer properly
Tip: Always maintain dual temperature control settings at equal or +/- 1 setting position.
How refrigerators work:
http://www.repairclinic.com/0088_4_3.asp
You will need to verify operation of the following components listed below:
1. Evaporator fan motor
2. Air diffuser assembly
3. Light switch for refrigerator/freezer light
4. Door switch
Click on the links to identify the parts listed
1.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di921541&PartID=921541
2.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di827263&PartID=827263
3.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di438889&PartID=438889
4.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di586519&PartID=586519
Parts breakdown diagram:
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
Posted on Aug 13, 2009
Kitchenaid side by side fridge is freezing food
you have a bad damper assy.when it gets cold enough in the fridge section the damper door closes so the cold air can't blow in from the freezer side,the door isn't closing allowing the cold air to keep coming into the fridge side 2220377 part number and this is electronic damper.if you order it from repair clinic you have 365 days to return it if it's damaged or it isn't your problem they will take it back,i'm 99 percent positive that this is your problem,when i would call the customer and get model number and ask a few questions i would take this with me when i go to the house from the discription you're giving.
Dec 05, 2013 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Model KSRG22FKWH04, stopped, lost the food in the freezer, fridge is not cold. What is wrong. Lost my job and can't afford a new fridge.
are the lights on and if so the power is ok . can you hear a clicking noise . if so it can be the compressor trying to start . and inside the freezer you should be able to hear the fan and under neath also ther is fan that should be going ck for a clean coil .. mm hopt some of these help you .. mm
Oct 14, 2010 | KitchenAid Superba Architect KSCS25INSS...
Fridge and freezer not cooling properly. bottom s...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
68rjszndh
May 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
Apr 24, 2009 | Refrigerators
My freezers works but my refrigerator
make sure all your fans are turning. maybe try to remove the knobs and see if you can turn them without the knobs, possibly they could be stripped.
Apr 22, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchenaid side by side too cold. Freezes everything.
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Feb 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Over temperature reset button keeps ringing and blinking
I called the KitchenAid customer support number. Found out that control goes off when the temperature of the fridge is above 48 degrees (i.e., over a few days, the food would be spoiling). This is not the case for ours, since everything seems to be working fine. They said there is probably something malfunctioning with that button/control, and there is no manual turn-off mechanism. We have to call someone to come and fix it.
Jan 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
How do i defrost a fridge?
To defrost a fridge, you simply move all of the food to somewhere it can stay cold and unplug the fridge. That's it!
The purpose of defrosting a fridge/freezer is to melt the ice that has accumulated around the condenser to restore it to maximum efficiency. Once it has melted (using a hairdryer can speed it up) you can plug it back in and put food back.
Mar 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
Superba kitchenaid fridge not very cold, freezer is fine
Sep 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Architect Series KSRP22FSSS 33" Superba Side-By-Side Refrigerator w/ 21.7 Cu. Ft. Capacit... Logo
176 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
