Question about LG VOYAGER VX10000 Cellular Phone
Broken Screen.... again This is my second voyager thats front screen broke on it 2 days after receiving I pulled it out of my pocket and bam fthe screen was cracked and it was either by some weird accident that i didn't know about or its just breaking in my pocket for no reason so is it that the screen on that phone is really easy to crack?
94 voyager is stuck in second gear. no check engine light
if you are not mechanical, or don't have the tools, like an engine horst, to work on this, my best advice is bring it to.a good transmission shop with these front wheel drive transmission, the engine needs to be supported to pull the transmission out sounds like a snap ring broke, or valve body needs a rebuild, it could also.be your governor not building up enough pressure, because when you shut if off, and start it again, your pressure builds up.again these front wheel drive transmissions are not fun to work on, so if your not familiar with these transmissions then it's best to.have a transmission shop fix for you
Dec 05, 2013 | 1994 Plymouth Voyager
Nokia N96 broken camera screen
u not require to change the whole chasis just change the camera screen it is possible have anice day
Sep 29, 2009 | Nokia N96 Cell Phone
Phone only goes to white screen.
well it happen to my phone so i went to where i got it n told them it went white out of no where n they gave me a new phone....
Jul 29, 2009 | Samsung Cell Phones
My front screen is black phone works fine just my front screen is black cant use the touch screen
I think all you need to do is take the battery out while phone is still on and leave out for about 30 seconds then replace battery and turn phone back on and u should have your screen again, at least it came back when i did it to my phone... hope this helps. Good Luck with that
Jul 09, 2009 | LG VOYAGER VX10000 Cellular Phone
LCD screen broken, have parts, want to know how to change them
THIS is what everybody else leaves out!!! first open ur phone and there are four sticker pads in the corner, use something with a sharp point to remove. Then use a phillips screw driver to remove the screws. the top with now come off, next there is a ribbon cable from the touch screen to the screen itself, On the connector there is a small plastic lever u will need to flip up in order to release the cable. Use a solder iron to remove the wires and it helps to write down on a paper where they go! do NOT LEAVE THE IRON ON THE WIRES TOO LONG!!!!! just enough to melt the solder and remove the wire, same for putting the new ones on! Next carefully remove the screen, it is held in place by sticky tape, be careful not to crack the cover, just be patience and do it slow! and put the new screen in in reverse order!!!! hope this helps!
Tallcool1
May 04, 2009 | LG VOYAGER VX10000 Cellular Phone
My voyager touch screen broke
There is nothing you can do about this. You will have to open the phone and use it like that. You can still make calls usinf the numbers near the top and then close the phone to talk or have it on speaker in the open form, but the screen will never display anything anymore.
Apr 26, 2009 | LG VOYAGER VX10000 Cellular Phone
The back screen on my kodak C743 is malfunctioning
You are correct. The LCD screen is broken. This is super common with the C743. It is unprotected and unlike most LCD's, there is no hard plastic or glass screen over the LCD. My wife broke my son's 1st 743 when she left it in her bag. My son broke the second one by packing it in his duffle bag for a summer camp trip.
You can spend about $40 for a replacement that will probably break again, move on to another camera or use this as a "green mode only" point and shoot camera just like the old days where you don't know what you got until you get home. You can still hook it up to your TV set to change the settings and review your pics, but that's all you are left with.
Jan 20, 2009 | Kodak EasyShare C743 Digital Camera
Is the screen bad or something else??
Sounds like some area in your screen will no longer connect. I lost about 1/8" of the right side of my screen. To run the calibration, I touched the screen left of where the dots appear. I had to tap the four dots about twenty times before it came out of calibration mode. That part of the display will probably never operate again.
Dec 24, 2008 | Samsung SCH-i730 Pocket PC
BROKEN LCD SCREEN
I have seen this with cameras, and pocket TV sets.
It is best to send the unit back for factory service. Ask for an estimate before servicing.
The parts in your GPS are not generic parts. You can buy the screen from the manufacture and find that the circuit board under it is also broken or damaged.
You may also find that the cost of the screen replacement may approach the cost of a new unit. I have seen this on many small devices. In some models the screen module comes as part of a complete matched assembly.
Jerry G.
Jul 01, 2008 | Navman NavPix N60i GPS Receiver
My screen crack
Shouldnt cost us any thing, i am on my 4th nokia 5300. the first one just plain died, screen stopped working, the next two lasted 2 weeks and 3 weeks respectivly before the screens cracked. I
I dont abuse my phones, i never dropped them in those times, just pulled phone out of pocket and the screens were cracked.
Filed a complaint with Nokia and also with T-mobile so at least i have some kind of history thast they can look at.
Oct 29, 2007 | Nokia 5300 Grey Cellular Phone
LG VOYAGER VX10000 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
