Question about Cycling
Knock when coasting (it's not the computer pickup, seems to happen more than once per tire rev)
    Problem Solver:
  • 5 Answers
Lift front end of the road/path and spin and listen for noise, this will help to locate the problem. Same for rear.
Posted on Sep 27, 2009
Transfer case fluid differential
go to a truvk specialist--thinc u mite need a new case and havum look at alinement and steering
Aug 09, 2013 | 1990 Subaru Loyale
Car stuttering
The rev limiter kicks in at about 6800 RPM to prevent "coast over" to unsafe revs, so I suggest you have a custom programmed PCM that eliminated the rev limiter feature or moves up the RPM limit.
Apr 19, 2017 | Cars & Trucks
What is the difference between tire size 255/70 and 265/70
Hello Projocs03,
Tires are typically measured tire width (sidewall)/tire ride height/wheel size. The differences of the two tire sizes you published are .4 of an inch difference in width/sidewall. And about .55 in over all diameter which would impact you revs per rotation. Depending on your wheel size.
Attached is a comparison of the two given the variable of 17" rim.
Stock Tire >Search Tires Tire 1 - 255/70R17 >Search Tires Tire 2 - 265/70R17 >Search Tires Section Width: - - Section Width: 10.03 in 255 mm Section Width: 10.43 in 265 mm Rim Diameter: - - Rim Diameter: 17 in 431.8 mm Rim Diameter: 17 in 431.8 mm Rim Width Range:
Rim Width Range: 6.5 - 8.5 in Rim Width Range: 7 - 9 in Overall Diameter: - - Overall Diameter: 31.05 in 788.67 mm Overall Diameter: 31.60 in 802.64 mm Sidewall Height: - - Sidewall Height: 7.02 in 178.30 mm Sidewall Height: 7.30 in 185.42 mm Radius: - - Radius: 15.52 in 394.20 mm Radius: 15.80 in 401.32 mm Circumference: - - Circumference: 97.54 in 2477.5 mm Circumference: 99.27 in 2521.4 mm Revs per Mile: - Revs per Mile: 669.8 Revs per Mile: 658.2* Source http://www.1010tires.com/TireSizeCalculator.asp?action=submit
I added the above link so you can research further or change any variables you need to know. However, the most important thing to understand is the impact of your speedometer. Different sizes will have different impacts. For example going to a bigger tire will show a slower speed on your spedo that your traveling.
Good luck
May 25, 2011 | 1997 Ford Expedition
Can 215/65/16 tires on a 1999 Caravan be swapped for 205/60/16 tires?
Yes, you'll be o.k. They don't recommend anything over 3% difference, and your at about 1.8%. Speedo will read 61 mph when actually doing 60 mph. Have a look.
Stock Tire - 215/60R16 >Search Tires Tire 1 - 205/60R16 >Search Tires Section Width: 8.46 in 215 mm Section Width: 8.07 in 205 mm Rim Diameter: 16 in 406.4 mm Rim Diameter: 16 in 406.4 mm Rim Width Range: 5.5 - 8.5 in Rim Width Range: 5.5 - 7.5 in Overall Diameter: 26.15 in 664.21 mm Overall Diameter: 25.68 in 652.27 mm Sidewall Height: 5.07 in 128.77 mm Sidewall Height: 4.84 in 122.93 mm Radius: 13.07 in 331.97 mm Radius: 12.84 in 326.13 mm Circumference: 82.15 in 2086.6 mm Circumference: 80.67 in 2049.0 mm Revs per Mile: 795.4 Revs per Mile: 809.9 Actual Speed: 60 mph 100 km/h Speedometer1: 61.0 mph 101. km/h Speedometer Difference: - Speedometer Difference: 1.822% too fast Diameter Difference: - Diameter Difference: 1.8%
Nov 07, 2010 | 1999 Dodge Caravan
Sounds like a clunking noise, like the sound you hear when you have a flat tire, Tire isnt flat. turning right on the wheel lessons the sound but stays the same turning left. noise seems to be getting...
its a wheel bearing. .will need to be inspected to determine the correct one. Also tires could also do this if the steel seperated internally. Rotate the suspected tire to see if it follows the tire.
Apr 03, 2010 | 1990 Toyota Pickup
2003 Ford Ranger Pickup traveling down the road
Is there somthing hitting the gas pedal, like the floor mat? Or maybe something under the dash came loose and is getting caught under the brake pedal and pushing on the gas. Put the shifter in neutral if you get into a situation where going to hit something or someone. The engine has a rev limiter, to prevent it from over reving.
Feb 10, 2010 | 2003 Ford Ranger Regular Cab
What is the biggest tire that will fit a 2004 GMC Envoy XUV with OEM 17" wheels? Will a 275/60-17 tire fit?
Stock Tire - 245/65R17
Revs per Mile:704.3
Overall Diameter: 29.53 in 750.06 mm
Tire 1 - 275/60R17
Revs per Mile:693.5
Overall Diameter: 29.99 in 761.74 mm
Speedometer1: 59.0 mph 98.4 km/h
Speedometer Difference: 1.557% too slow
Diameter Difference: 1.54%
Will fit with the stock rims.
Dec 14, 2009 | 2004 GMC Envoy
Thanks to 'Double Clutch', more info
If the rear tire is bolted down and torqued properly then the chain should not move the rear tire. Try taking the chain off the bike completly and if you can remove the sprocket cover and run the bike and maybe see what going on. Check the chain links while it is off to see if they move freely.
Oct 03, 2009 | 2003 Triumph Daytona 600
MY 1997 NISSAN XE 2.4 LITER, 4 CYLINDER, 5-SPEED STANDARD 2WD TRUCK WILL NOT GO IN REVERSE WITH VEHICLE BEING STILL WITHOUT KNOCKING IT IN GREAR WITH YOUR FIST BUT IT WILL GO IN GEAR IF YOU ARE COASTING...
With the vehicle sitting still, ease the clutch out just a little bit while trying to engage reverse. If it pops in, even with a little grinding, it seems the bearings on the counter shaft may be a little stiff. Have you checked the level of the gear lube in the transmission?
Jul 28, 2008 | 1995 Nissan Pickup
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
