Question about Epson Perfection 1670 Flatbed Scanner
Can't get power to scanner. Can the transformer go bad
  • 138 Answers
Check the power cord is connected tightly, ,, and power is comming from your power \source,, or else the connecter can be problem.. replaced
Posted on Sep 27, 2009
How to test for bad transformer
  1. To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
  2. You will still test the transformers the same way for step up and step down transformers. If it is a step up transformer apply the incoming power to the transformer or plug it up. Now take your multimeter and place it on the AC volt scale and test the voltage if the voltage on the data plate says the transformer should step up to 220 volts and it doesn't then your transformer is bad.
  3. Now repeat the same steps for a step down transformer. Plug up the incoming or primary power and test voltage on the outcoming or secondary side the voltage should step down to the proper value. If you don't read any voltage on the secondary or outgoing side then the transformer is bad.
  4. To read the voltage place the two meter leads on the secondary side, or the side you will plug your equipment into. If the secondary side is an outlet then place the two meter leads into the top two slots in the plug and read voltage. You also want to make sure the incoming power is working as well. Otherwise you will be reading a bad reading every time.
Dec 16, 2011 | Emerson LC320EM8 32 in. LCD TV
No power to unit with transformer plugged into working outlet
First check if ur transformer have power using digital tester if you have tester.Then if trnsformer have power,check the power supply adaptor if they have 12vdc outpot supply. This checking is to make ur that ur scanner is good.
Jul 01, 2011 | Canon CanoScan 4200F Flatbed Scanner
My HP Scanjet 5400C Scanner has decided to stop working. The 12 volt mains transformer feels cold and no light comes on the scanner. It appears that the transformer is US. Where can I buy a replacement
You can probably get this from HP. See http://h20141.www2.hp.com/Hpparts/Search_Multi_Product.aspx?mscssid=42F39AE6AD6B4EFBBC921EC42BADCDE3&SearchCriteria=Scanjet~5400C and select your model. There are 4 versions of the ScanJet 5400C listed. Then select power module in the drop down menu and click on the arrow; power cords are listed separately. Alternatively, click on the arrow for show all parts. The listings are clearly labeled for the country electrical system with which a given part is compatible.
I hope this helps.
Jan 08, 2011 | HP Scanjet 5400c Flatbed Scanner
Astra 20000U lost the power supply where to get replacement transformer?
if you can see the voltage and amp requirements either on the machine near where it would plug in or a manual then I have picked up the transformer at radio shack and they have a set of different ends to plug in on the DC side
Oct 01, 2010 | Umax Astra 2000U Flatbed Scanner
My computer will not recognize the pandidgital photolink scanner
Try attaching the scanner directly to the computer. If this works, the problem is obviously in the hub. Many scanners will not work if attached to a bus-powered hub. If you have a self-powered (with a power transformer) hub, double check that the power transformer is working (it should be warm).
I hope this helps.
Dec 25, 2009 | PANDIGITAL Office Equipment & Supplies
Low Hum Noise in Bearcat III Scanner
Yes, it does sound like a bad power transformer. Try powering it using a DC supply or battery and see if the hum goes away.
Mar 27, 2009 | Uniden BC60XLT-1 Handheld Scanner
Transformer problem
HI amperage is1.25A Have the same problem myself. only one that I can see avaible is from the Xerox UK website @ £15.00.
Mar 05, 2009 | Xerox One Touch 2400 Flatbed Scanner
HP 4070 Doesn't Power Up
Power requirement per HP specs is 12VDC @ 575mA 6.9w. My scanner and power supply shows 12 VDC @ 1250ma.Over double the power going in that required. No wonder the fuse blows and you have to buy a new scanner because you can't identify or get a replacement fuse. I would suggest you confront HP and have them supply you with a new scanner.
Aug 07, 2008 | HP Scanjet 4070 Flatbed Scanner
Epson Perfection 1670 Flatbed Scanner Logo
138 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
