Question about Foxconn 6150BK8MC-KRSH Motherboard
Ram I have 3 sticks of 512 each in my mother board (foxcomm 6150bkmc), it should show 1.5 gig of ram but it only shows that it has 960mb. ive tried the ram in my other computer and it works fine in it. help me if you can. thanks mike
  • 31 Answers
If you are using a built in graphics card then thats probably where the lost memory is going.
Posted on Dec 23, 2007
  • 37 Answers
Maybe one of the memory slot on your motherboard is faulty. Try testing each slot by placing one memory module on a slot and start your pc. If your pc made beeping sounds, that slot might be faulty. Do this on the other slots.
Posted on Dec 18, 2007
Trying to upgrade ram, only reading 512 instead of the gig i put in, can i reset jumpers or is there any other way. i don't have motherboard manual
you can only have the gig stick the board is older and can only utilize 1 gig at most take out the 512 and your gig will show up i promis
May 10, 2010 | EPoX EP-3WTM3 Motherboard
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
Ram issue - GA-8VM800PMD-775
This Type Mother Board Comes With DDR2 RAM.
Go to the Nearer Computer Pheripheral Store Ask for 1 GB or 512 DDR2 RAM..there are several brands Simmtronics,Hynix,Transcend. You can get u r choice.
Jul 08, 2009 | Gigabyte GA-8VM800PMD-775 Motherboard
DDR2's only showing half installed RAM
IF THE SYSTEM SAYS YOU HAVE 1GB RAM THAN YOU HAVE 1 GIG OF RAM, EVEN THOU SOMEONE TOLD YOU YOU HAD 2-512MG=1GB.
HERE IS HOW I SEE WHAT YOU ARE SAYING YOU HAVE 2-DDR-2 1 GIG STICKS THAT MEAN IF 1 IS INSTALLED THAN YOU HAVE 1 GB AND IF YOU COULD GET 2 STICKS WORKING TOGETHER THAN YOU WOULD HAVE 2GB RAM.
1 CHIP SET = 1GB RAM
2 CHIP SET = 2GB RAM
YOU MOTHERBOARD MAY NOT ALLOW THAT MUCH RAM, OR WHAT I MEAN THE BIOS MAKE UP THE AMOUNT OF RAM.
TO RULE OUT ANY BAD CHIP SETS OR GOOD RAM OR BAD RAM.
TAKE THE PEACE OF RAM THAT IS WORKING OUT AND REPLACE IT WITH THE OTHER PEACE AND SEE IF IT WILL RUN.
IF IT WORKS THAN LEAVE THAT ONE IN PLACE AND INSTALL THE SECOND PEACE IN THE SECOND SLOT.
IF BOTH CHIP SET ARE GOOD THAN BOTH SHOULD WORK OKAY TOGETHER.
IF THERE IS A PROBLEM, IT MAYBE SOME DUST IN THE MEMORY LOTS
OR THE SLOT MAYBE DAMAGED.
OR
THE CHIP DESIGN LAYOUT MAYBE THE OPPOSITE SIDE, THIS MAY MEANS THE CHIPS MAY FACE EACH OTHER, OR FACE OUTWARD FROM EACH OTHER.
ROD
Mar 14, 2009 | EliteGroup P4M800-M7 Motherboard
Adding ram, but computer freaks out.
there is a jummper on the mother board you need to take off.
Jan 05, 2009 | E-Machines eMachines Desktop PC
One of the ram isnt recognised???
This is likely a memory timing incompatibility. You can go into the BIOS settings of many motherboards and set the timing specifically for each RAM slot, but without knowing exactly which piece of RAM you have I can't tell you what to set it at. You could use the utility CPU Z, install one stick, run the utility and write down all the memory information, then install the other stick and write it down too. Then go into your BIOS and see if you can set all of your specifications to match the memory.
Of course if you could find someone to swap sticks with that would be easier. Some motherboards are more picky than others about which sticks they work well with, name brand manufacturers are more picky than aftermarket in general.
Dec 30, 2008 | Computers & Internet
Memory
if you have two sticks of ram .... 256 each one is not working... take them out and reseat them. if that doesn't work swap slots.... you are likely using about 8mb for system video or perhaps more so you are not likely to show a full 512 mb.
Robert
Sep 15, 2008 | Gigabyte Computers & Internet
4gigs ram
Switch sticks around in various combinations (2 gig in slot one, 1 gig in slot two, switch, try other stick, etc) and see if it is the memory or the motherboard.
Sep 10, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
Foxconn 6150BK8MC-KRSH Motherboard Logo
361 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
