Question about Hotpoint TDC32 Electric Dryer
Hotpoint Utima Logic Sensing Condenser TDC62
When turning on to dry you can here a click but the drum does not turn. Heat is being generated. When you turn to the airing cycle the drum turns. Any ideas. Having moved out to NZ recently need to know if its worth fixing and where I can get parts. Thanks
  • 833 Answers
Lewensc...this sounds like a classic timer issue. Before replacing it, first turn off your mains breakers and then back on. Check all wiring from the breaker panel to the unit. If okay, then have a quick look at the items in the dryer and test them using a multi tester. If nothing is amiss, replace the timer.
Posted on Dec 18, 2007
Hotpoint Ultima Condenser Dryer TDC62 - No Heat
That trouble is cause by an heater that is already open- no connectivity. Also the wire connected to it.
I hope I answer your problem.
Mar 23, 2011 | Hotpoint Dryers
Hotpoint ultima logic sensing condencer TDC62 is not drying clothes, it doesn't appear to be heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Dryers
I have a hotpoint tdc62 when on it works fine apart from a grinding noise when the drum is going round could it be the belt? its 5 years old never been changed many thanks
More than likely worn rear drum bearing or worn front bearings.
Remove the rear panel, and you should see the drum shaft, check for wear here.
Jan 15, 2010 | Hotpoint TDC32 Electric Dryer
Hotpoint condenser dryer drum workinbg no heat
check the temperature switches in the back for continuity and also the moisture sensor on the exhaust housing at the rear of the unit. all these switches should be normally closed.
good luck...jay
Apr 23, 2009 | Hotpoint Dryers
Dryer drum will not turn
check to see if there is a little red button on the back if so push it in thats your re-set button
Mar 24, 2009 | Dryers
Hotpoint TDC62 condenser dryer does not heat up Hotpoint TDC62 drying light does not come on. It flashes briefly when you press the start button but then goes straight off. Why? If you tap the machine the...
Most likely, the orange relay switch (Schrack RT314024) on the circuit board of the dryness module (blue colour) is faulty. RS electrics and Farnell has it. Costs £2.50. Mine had the same problem and changing it sorted it. I also replaced all the four small electrolyte capacitors on the circuit board (which you don't have to replace - I am a bit fussy with capacitors).
Your thermostats and heating elements are good (don't change these).
Jan 17, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC62
your dryer is probably worn out in the area of the front slide assy / bearing. They all do it. the drum is binding and stopping the motor sometimes...can be noisy too...
Oct 15, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC62 condenser dryer does not heat up My hotpoint tdc62 does not heat up. I had it for approx. 5 yrs, have changed the thermostats(years) before,but have come up with a new (recent)problem. when...
I think the problem still lies with the thermal switches, they have a tendancy to corrode where the spade connector attaches to the body (see pic)
Mar 11, 2008 | Dryers
your thermostats have most likely gone they are situated at the back of the machine on top of the heater
Feb 09, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
132 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
