Question about Dryers
FUSIBLE LINK KEEPS BLOWING - Dryers
    Genius:
  • 1,474 Answers
There is a short circuit present, could be the motor or heater
Posted on Sep 27, 2009
I purchased a 4 terminal starter solenoid. A 3 terminal was on truck. This 4 terminal solenoid includes an S and an I terminal. Is the I terminal used on a 1987 Ford Ranger 2.9 V6 4WD?
If the truck had a three terminal one on it then you would not use the (I) terminal, nor would it cause you to keep blowing your fusible link. It would cause a hard start cold because all the (I) terminal does is feed 12v directly to the coil on cranking. You have a short in the circuit that is on that fusible link. You need to get a wiring diagram and see what that circuit feeds. If the fuel pump isn't running than disconnect that circuit and see if it keeps the link from blowing. You may have to get a circuit breaker to install temporarily it to help find short. I have used a breaker and have gone directly to the fuse box and feed there to help isolate which circuit it is in. Good luck.
Jun 14, 2015 | 1987 Ford Ranger
Fusible link alternator keeps blowing
Not a lot to work with here, but I will say that if a fusible link continuously blows out, you have a problem that needs fixing either with a short in the wiring or a bad component being the issue. The first thing to check would be to check the "line in" voltage and amperage going to the fusible link. Work your way "upstream" ruling out components as you go using this testing method. Once you find a point in the line that has the correct input, you have found your trouble component. The component that has the correct amperage flowing into it, and the incorrect flowing out is your issue. You may also find a short in the wiring somewhere along the line which could also be the issue.
Dec 24, 2012 | 1985 Buick Century
I have a 1994 Honda Accord. The 40 amp fusible link keeps blowing after 30 minutes of replacement. Any suggestion?
You will have to find out what circuit or circuits that link delivers power to, then look for the short-either a stripped wire contacting metal, or a component like a failed motor that is pulling too much current.
Is it a fusible link or a maxi-fuse? Check if it could be for the alternator.
Nov 27, 2012 | 1994 Honda Accord
Nissan pathfinder 2009 fusible link on engine compartment keeps blowing upon replacement engine wont starts, and the dashboard (INOP)
Someone will have to check the wiring to find the short to ground.
You may need a shop manual to get the necessary diagrams.
Sep 29, 2012 | 2009 Nissan Pathfinder LE
Main fuse keeps blowing. changed battery and installed radio. brand new fully connected postitive termial, vusually checked all wires coming off battery. some sort of radio relay clciks when radio plugged...
Hello! Identify which fuse is blowing...also, does it blow as soon as it is installed or does it blow when you turn the key? Lastly your not referring to a fusible link but a maxi-fuse...ie...40; Correct?
Oct 16, 2011 | 1994 Chevrolet Suburban
20 amp MPI fusible link keeps blowing. turns over but acts like getting no gas until you replace fuse stars fine then blows again.
hi it is must likely youer fuel pump
after replaceing fuse lising for loud nose from
pump if so replase pump
Dec 03, 2009 | 1988 Mitsubishi Pickup
80a fusible link 95 4runner keeps blowing
You either have a short somewhere, or the alternator is over charging. What does the volt gauge read before it blows, if you don't have a gauge, get a volt meter and test at the battery. Anything over 14.5 will blow the link.
Jun 10, 2009 | 1986 Toyota Pickup 4WD
Fusible link keeps blowing any ideas on why or what i can do to fix it
check you main grounds clean the area of connection
May 17, 2009 | 1995 Isuzu Rodeo
Electrical. alternator fuse link keeps blowing
The wiring harness coming from the solonoid/power distribution has one small guage wire splitting into three different medium guage wires. I have ran into this problem quite often on mustangs, and what I have found that works is take the split out of it, and run all three wires with fusible links added to them straight from the solonoid
Jul 31, 2008 | 1989 Ford Mustang
Dryers Logo
48 people viewed this question
Top Dryers Experts
