Question about Dell P1130 21" CRT Monitor
Moving shadow bars - on applications & windows only
My monitor just started showing gray shadow bars with any lines of type, graphics or pictures on any open window - in all applications and online. Everything I see tells me it's possibly the video card, however, there are no bars on my desktop when no programs are open, and no bars when my photo slideshow screensaver is going. When applications are open, and I scroll up or down, the bars do extend across the desktop. If it is the video card, shouldn't they show all the time?
  • 138 Answers
Hi, generally it happens when an video card is faulty.. try replacing the video card,, it should work fine..
Posted on Sep 27, 2009
My panasonic plasma tv 32inches is show a gray color picture at d middle of about 4inches from top to down.and the other both side picture is fine wat can i do
Sounds like damaged COF [Chip On Filim] strip. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 06, 2015 | Panasonic Televison & Video
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
My laptop isn't working . Turns gray then white with various color lines
If it's new return it. OR, Connect to a External Monitor, if the issue shows in the External monitor it's most likely the Graphics Adapter. Try booting to Safe Mode, do you see the same problem? Have you done ALL the Windows and Compaq Updates? Is it overheating due to poor air flow from the fan (bottom) and side vents? Has it been damaged?
Mar 28, 2013 | Computers & Internet
Compaq C700 laptop screen shows horizontal lines and the screen seems to be split into several sections
The LCD screen is faulty and will need to be replaced, go to www.ebay.com Type: make and model refine search to screen, first! hook a spare monitor to the video output usually on the back, if picture okay! the above mentioned needs to be changed, but! if both show the same symptom it is the video graphics card that is part of the motherboard.
Apr 19, 2012 | Computers & Internet
Monitor Picture is Blurry because of shadows
If you've already checked all your cable connections, to make sure they're tight, check your windows settings: Go to Start>rt click My computer, choose properties, settings on performance, and choose adjust for best performance. (This will uncheck the shadow options for menus and icons, etc.) Take a look at your desktop. Is that better? If so, you might want to do some maintenance to improve your system performance by clicking here.
If no improvement, download or open the .pdf user guide for your monitor by clicking here. See pages 22, 17, and 12. They will show you how to use the auto button on the monitor to reset to optimal settings, to adjust the refresh rate (control panel>display>settings>advanced) to its optimum. (Normally, higher refresh rates indicate clearer pictures, but some LCD monitors seem to run better at a default 60hz rate. Check your Gateway documentation for your graphics adapter to see what it supports, (your monitor supports 60, 70, & 75), or experiment.)
If adjusting settings doesn't improve anything, you could search for updated drivers for your graphics adapter. Go to windows update and see if you're offered hardware updates, or search Gateway support for newer drivers.
Not many options left. See here.You could take it in to a local tech and have them take a quick look.( or try it on another computer).
If it's on its way to a sad end, I'm sorry. We have the same monitor at home and it's been great. Aside from a scratch someone put in it years back, it provides very clear resolution.
Apr 18, 2009 | Gateway FPD1760 17" LCD Monitor
Some black colors are replaced with red blue flickreing in whites
Hi there
Firstly reinstall the graphics drivers, if its still the same there is a problem with the graphics card and you'll have to have it looked at.
Good luck and thanks for using Fixya!
Feb 06, 2009 | Fujitsu LifeBook C2340 Notebook
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
Open Questions:
Dell P1130 Blue Channel Problems I've had this monitor for over 4 years now - and it's been going strong since 2002, according to the manufacture date. Over the last year it's health has declined, and the blue channel used to flicker and strobe and pop at me when I switched it on in the morning, but calmed down after a moment and was perfectly normal for the whole day. Recently I turned it on after a couple of days away, and it was yellow - the blue channel didn't even seem to turn on with the rest of the monitor. After trying a few things, including some careful blows from my open hand to the sides, I pulled the plugs out and set it face down on the carpet, and went to find a screwdriver. I cam back, looked at it, and thought - I'd better find out how to discharge the capacitors before I do this. So I set it upright and switched it back on, but this time the blue channel popped on and did it's flickering thing! Almost as though turning it face down fixed it. That state has lasted for a couple of days - and the blue channel has worked ok, but when I switched it on this morning, the blue channel woke up, but then didn't cough into life, so now it's a yellow screen again. I took the back off and vacuumed the dust out, looking for scorch marks and leaking capacitors, but I couldn't see any - my guess is a loose wire leading from the power supply to the electron gun is loose or something like that. I love this monitor a whole lot, and because of it's superior color depth, I haven't wanted to get an LCD until I really had to. What I would like is an explanation of how the blue channel is wired to the electron gun, so I can check for loose wiring, and possibly a leaking capacitor that I haven't noticed yet, as well as the location of the capacitors inside the monitor case. I've been very careful - I've read a few articles on the subject, and I avoid touching anything except the outsides of the case. I know not to mess with things I have little knowledge about. However what I'm looking for is just some information about the blue channel's wiring arrangements, so I can check for loose wiring, or leaking capacitors, or shorted circuit boards.
Nov 23, 2011 | Dell P1130 21" CRT Monitor
Dell P1130 21" CRT Monitor Logo
137 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
