Question about Exercise & Fitness
How do I adjust the hip support up and down on a Exercise Skier?
How do I adjust the hip support up and down on an old Nordic Trac Ski Machine? Or is it one size fits all?
    Habit-Forming:
  • 115 Answers
It depends on the unit. Your might not adjust. Other units adjusted by pulling a pin, and the top of the line club unit you pulled back on it and raised it
Posted on Oct 09, 2009
I need BC 887 manual
[DOC]Nordic Track Achiever Manual
188.166.107.131/nordic-track-achiever-manual.doc
... owners manual pro achiever etc ebay , nordic track achiever bc 887 manual ...nordictrack treadmill achiever reviews viewpoints , nordic track skier exercise ...
[DOC]Nordic Track Skier Manual
188.166.107.131/nordic-track-skier-manual.doc
... treadmill manual google sites , ntl nordictrack nordic track c manual sears , nordictrack ntl 1 user manual pdf download , nordic track achiever bc 887 manual ...
achiever bc 887 Treadmills Questions & Answers - Fixya
www.fixya.com > Forum > Tags > achiever bc 887
Treadmills achiever bc 887 questions and answers. Ask your ... Where is the ENTER button? please follow the instr.manual if you do not have it download it from ..
Jan 14, 2016 | Exercise & Fitness
RESISTANCE PROBLEM WITH FREEMOTION 350R
9 out of 10 times the issue is a worn out clutch bearing or "one way needle bearing". Freemotion and Nordic Track are both owned by ICON Fitness. This technology for fitness equipment comes from the original Nordic Track skier. In the skier, there is a flywheel with an axle through it in the middle with skis left and right. Under each ski just about center of the length is a rubber roller that fits over the flywheel axle. Inside this roller is a "one way needle bearing". That is, when you push to the rear with the ski, the bearings rollers will shift and lock against the axle and engage the flywheel. When you pull the ski back forward the rollers inside the bearing release the axle and allow free movent forward untill you again push to the rear. Many poor souls were sold new skis and tension straps in most cases to no avail. What needed to be replaced or rebuilt were the rubber rollers under the center of each ski with the "one way needle bearing clutch" inside. The same technology is used inside this exercise bike except that the "one way needle bearing" is pressed directly into the flywheel itself. So rather that replacing or rebuilding the "roller clutches", you need to replace or rebuild the "flywheel". The price for the flywheel from ICON is $600 plus. Thats right $100 more than you probably paid for the bike. There used to be businesses that rebuilt the roller clutches for the skiers. There is no rebuild service available for the flywheel on this bike. So if you don't buy the maintenance contract witch will cost you as much as the bike for 4 or 5 years you have a very heavy piece of junk to dispose of. This is planned obsolescence at it's best. If you are very handy. You can disassemble the bike and find a commercial machine shop that can replace the bearing for you. It is sandwiched between roller bearings on each end. You will need a press designed to remove and replace bearings for commercial machinery like conveyor belts and assembly line equipment and someone to order and replace the same or an equivalent bearing. This actually should be a relatively affordable service. At least in comparison the only other option.
Oct 30, 2013 | FreeMotion 350R Recumbent Bike
NordicTrack Classic Pro Skier has a noisy pulley
1) LUBE the deck belt inmediately, maybe you have now a WORN deck belt time to replace.
2) LUBE the rollers bearing TOO.
3) test the voltage input motor, if there are the motor NEED repair
God bless you
Oct 14, 2012 | Nordic Track NordicTrack Classic Pro Skier
Looking for a manual for an old lifestyler (weslo) rower and x/c skier exercise machine, number 831/29044
You may have to call iconfitness.con since this is their product, they may have the manual in their Dungeon call them @ 1800-999-3756 GOOD LUCK!!!
Jul 10, 2010 | Exercise & Fitness
Nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Jun 12, 2010 | Nordic Track Exercise & Fitness
Missing a part on the tension belt for a Nordic Track Achiever
Go to Iconservice.com click on manual input Nordic Track Skier their is 47 matches the friction band tensioner should have a clear diagram of that mechanism
May 29, 2010 | Exercise & Fitness
Looking for manual for basic nordic track -- basement was flooded
Go to www.iconservice.com and Input Nordictrack Pro and you will find a manual for your unit
May 05, 2010 | Nordic Track /proform Treadmill...
Instructions for a Performance-Track indicator.
i do not know much at all on exercise machine but i would like to help. i saw a picture of what you are talking about and i you sure it requires power and if you are sure that it does it might take a watch battery so there might be something to unscrew
May 10, 2009 | Computers & Internet
Exercise & Fitness Logo
77 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
