Question about Garden
I have a Craftsman Push Rear Bag Lawn Mower w/ High Wheel it's a 6.50 Briggs & Stratton Engine. I changed the oil by turning over the lawn mower and draining the oil from the dip stick hole. I also took off the air "filter" to change the air filter but I guess it doesn;t have one. Having replacing the oil it started okay but it runs very rough and still smokes. What would cause that. Also on the air filter container they is a lever maybe I didn't put that back in place properly. is that for the auromatic choke?
  • 28 Answers
Your mower should definitely have an air filter whether it is paper or foam, and you should drain the oil from the bottom, not turning it over. turning it over can get oil in places where it shouldn't be and make it smoke or not run at all. It may need carburetor cleaning and spark plug cleaning or replacement, or the flywheel key may be sheared if it runs rough
Posted on Oct 03, 2009
Mower can not start
Does it have spark? Does the engine get fuel? If you spray starting fluid into the air filter will it start up?
Sep 20, 2016 | Craftsman 675 Series 190cc 22" Briggs ...
Where do you spray carburetor cleaner in 675 series Briggs & stratton engine
Remove the air cleaner cover and the air filter then spray into the filter box.
Jul 14, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Where is primer on craftsman platinum push mower
It may not have one. Some mowers auto choke using spring tension on the choke plate in the carb. They open the choke when the engine speeds up after starting.
Apr 23, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
What kind of oil goes in my craftsman 625 model 944.367600
Tecumseh engines usually recommend SAE 30 oil. Briggs engines allow 5W 30 or 10W 30.
Aug 01, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Mower under flood water for 2 days.
Hi Steve.You will need to get under the starter pully and rub the spark generator with some glass paper and WD40. No doubt the generator has gone a bit rusty due to the water.The fly wheel will need cleaning to. Also give it a warm place to stay for a few days to completely dry it out. This should be ok then. John
Jul 02, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Briggs and stratton 15.5 horse power over head valve
could be to much oil in engine are bad rings in engine or bad valve seals one of those three i would go with bad valve seals
May 14, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Briggs & Straten 5.5 oil spraying out the muffler
Check the compression, probably you need need a valve job
Mar 20, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Cannot find drain to change oil.
Poulon 550 yellow 22" Briggs and Stratton. It looks like you have to drain it out the cap by tipping it. There IS no plug on mine - spent 40 minutes looking for one, and I know what both types of the plug look like. What a lousy design. This mower is a piece of junk. The valve froze a week after I got it. Never again. A headache.
Dec 13, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Garden Logo
230 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
