Question about Tylo SPORT-U4 Heater 4.5 kW
Tylo Sport 6 6kw Sauna Heater tripping electrics.
I have a Tylo "Sport 6" 6kw Sauna Heater. After a couple of minutes from switch-on it is tripping the electric circuit. I have completely cleaned and checked it, and there are no obvious faults. Is this a common problem ? Any advice as to the likely cause ? Many tks. Peter.
  • rahatfaraz May 11, 2010
    Solution chack on this site www.solve.tk
3 Suggested Answers
  • 9 Answers
SOURCE: heater only gets mild warm Tylo sport 4 heater
more than likley installation problem not enough voltage top operate heating element
Posted on Feb 01, 2010
SOURCE: My tylo supersport 8 sauna
Remove the unit bottom panel (2 small screws) and look at the quick disconnect terminals on the heater rods ( 6 heating rods - 3 on each side of the unit). If you have any corrosion on these terminals, the wires will overheat and fail, preventing the heating rods from working. If the wires did overheat, you should see melted wire insulation. Replace bad wire and quick disconnect terminals with new. Should cost less than $20.
Posted on May 29, 2011
Tylo super sport 2/4 sauna heater. Unit will not heat.
check fuses to ignitor if blown check ignitor if ok check pressure switch
Sep 27, 2015 | Pool & Spa
My Tylo sauna high limit keeps tripping
overheating check voltage if ok bad heater element
Jan 28, 2014 | Tylo Sauna Heater HETYSPRTU2 22 kw
Where is the safety shutoff on a Tylo super sport 7
On top of the unit/sauna, you will need to remove the roof or wood covering. It is held down with screws, usually. If your unit in fact does have a reset it will be located on the side of the control box which is located on top of the sauna.
Jan 15, 2013 | Tylo Super Sport 7 Sauna Heater
My tylo sauna will not switch on
check fue inside if bad check heater
Sep 07, 2012 | Tylo COMBI-U7 Sauna Heater
Tylo sauna heater won't heat
if not calling for heat check temp sensor
Jan 19, 2012 | Tylo COMBI-U7 Sauna Heater
My tylo supersport 8 sauna no longer produces heat. The timer works but there is no heat. I have checked the circuit breaker but that doesn't appear to be the problem. Any thoughts??
Nov 23, 2010 | Tylo SUPER SPORT-U8 Sauna Heater 8 kW
Heater only gets mild warm Tylo sport 4 heater
Jan 23, 2010 | Tylo SPORT-U2 Sauna Heater 2 kW
Tylo SPORT-U4  Heater 4.5 kW Logo
633 people viewed this question
Top Tylo Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Tylo Pool and Spa Expert? Answer questions, earn points and help others
