Question about Ruud UBHC Air Conditioner
Cool air, but no fan, electrical smell inside house
The AC unit on the roof runs and I can feel cold air inside the house at the filter vent, but the fan that blows the air around to various vents doesn't seem to be running (can normally be heard when it kicks on). The same filter vent with cool air has an electrical/burning smell. System had been running ok up until yesterday. It is off now, and a technician is coming out on Monday, any suggestions?
    Problem Solver:
  • 14 Answers
Most like it the motor windings are burn and you need to replace the blower motor
Posted on Sep 28, 2009
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
May 27, 2010 | Danby DPAC8020 Air Conditioner
Heater smell when AC comes on...
The fan that blows the air blows through the heater coils before it blows through the A/C.As long as the heater doesn't come on, there is not much that can be done. ZCooking the attic room will be a problem because it is the heat rises thing, and on top(literally) of it all, the roof is radiating heat.
Sep 21, 2009 | LG Heat cool Window Air Conditioner
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Whirlpool microwave oven mh7155xmb0 not venting
Possibly a bird built a nest (swallows) in or on the roof vent. Make sure the fan turns freely when off. Check the vent tube that goes up to the roof--if flex-tubing, it may have collapsed and pinched off the air flow (it may be too long). Make sure that a one-way valve which should be near the exit of the hood is free to move when air flow pushes on it. This valve is supposed to prevent back-flow of air into the house. Hope this helps!
Mar 09, 2009 | Whirlpool MH7155XM Microwave Oven
Bad smell from ac unit in my house
does it smell like literally , dirty socks?if so it is dirty sock syndrome, a plague of heat pumps for years. if it smells like an electrical melting or burning of wires then time to call a pro.it could be a weak capacitor or a weak fan motor. if it is dirty sock syndrome then its the microbes that thrive when temps are middle temps and reproduce when temps are hot and cold in intermittent days. hot one day and cold the next equals call for cool then call for heat and hot steam from heated coils cause s bacteria to grow and microbes to spread across coil. when you switch back it causes the smell.if the coil is clean you can spend a chunk of money on sanitizers but best bet is to run it cool for hot weather and hot for cool weather. the transitional periods are what create the smell. avoid semi cool and semi hot periods. this condition is common to acs from all brands . lots of stuff on the internet about dirty sock syndrome
Oct 31, 2008 | Sharp CV-P09FX Air Conditioner
Blower Turns off if ac unit comes on. No air coming through vents
This only could 1--2 things, a bad circuit board fan relay or bad thermostat. To check for bad thermostat, take off the front cover to reveal the 4-wire terminial and jump the red-wire (power)-cool,(yellow -y or blue)--- green--fan white-(heat)..........red to yellow-or y=cool. Thank-you-very-much!
Aug 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Ruud UBHC Air Conditioner Logo
278 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
