Question about Whirlpool Refrigerators
Have whirlpool side by side model #ED5LVAXBOO-open & close freezer door & can not open refrigerator door for about 5 seconds till air "escapes" from top right of refrigerator door.(if you really pull refrigerator door I can then pull the whole unit away from the wall!) Is this normal? - if so, this feature really sucks..
  • 1122 Answers
SOURCE: WHIRLPOOL BOTTOM FREEZER / DEFROST
why do you want to defrost your freezer?is it not frost free?if so you have a defrost problem,but if you want you can unplugg it and use a hair dryer to defrost it,let me know how you do-mike
Posted on Oct 30, 2008
  • 311 Answers
SOURCE: Gladiator fridge/freezer not getting cold, not sucking in air
Is freezer fan running?
Posted on Nov 28, 2008
SOURCE: Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Posted on Jan 23, 2009
farfield
  • 462 Answers
SOURCE: Refrigerator door won't stay closed
Pull on the gaskets some times they are broken and will take up moore room that when correctly aligned. especially on the side of the door where the hinges are. Inspect thehinges also see of brackets are loose. If the gasket is bunched up on the hinge side try duct taping them down and retry the door. If this corrects problem replace door gaskets. If a plastic grommet is missing in the door it will nolt align correctly and you will be able to pick up on the outer corner of the door and it will wobel and be loose on the hinge. ReplACE THE GROMETS and retest and align as nessary.
Posted on Jun 19, 2009
HIRAM517
  • 59 Answers
SOURCE: Amana botton freezer buzzing 10 sec, freezer not cooling
CHECK MICRO/ SW WIRES @ FREEZER INSIDE THE CABINET COULD BE LOSE
Posted on Aug 19, 2009
Gd5sha water under the freezer
This normally occurs when you have a large buildup of ice in the freezer, when it does a defrost there is just too much water for the hat on the compressor to handle. Make sure the door to the freezer & fridge is closing properly & the seal is in good condition & not falling off, moisture in the air causes frost in a freezer. So too many door openings can cause the same problem.
Nov 20, 2013 | Whirlpool Refrigerators
When I close the fridge side the freezer side pops open a little and stays open. The appliance is 5 years old. This started very recently
a couple of problems can cause door problems first open door and check seal for damage [popped off trac or rip-tears]other is hinges worn- bent-loose --if seal is good at top and bottom of door are hinges check for loose if loose tighten -if bushing lookes like a little round washer type is broken or missing replace --needs realignment loosen top hinge and close door and adjust till door is straight and stays closed tighten door hinge done good luck
Jun 28, 2011 | Jenn-Air JCD2389G Side by Side...
I have an Estate refrigerator by whirlpool Corporation, model # TT18DKXRQ01 with a 12-07 mfg. date. When you open the refrigerator door, as it closes, the freezer door always opens and closes. Apparently...
I also own a model # TT18DKXRQ01 Estate refrigerator and my freezer door pops open when I close the refrigerator. As you stated, this is caused by the magnet in the freezer gasket not being strong enough to hold. As far as I know, they do not make a stronger freezer gasket but even if they did, it would probably be too costly considering that a standard gasket replacement costs $80.
My solution was to install an adhesive child safety lock on the top of the freezer near the door handle. I purchased the 'Safety 1st Lock Release Fridge Latch' model # HS038 from my local Walmart store for around $5.
You may find this solution to be slightly inconvenient at first but you will get used to it. It sure beats losing food because the freezer door was accidently popped open.
Product information:
http://www.safety1st.com/usa/eng/Products/Home-Safety/Latches-Locks/Details/482-HS038-Lock-Release-Fridge-Latch
Oct 13, 2010 | Estate Refrigerators
Vent flows cold air through frezer to right side when door open, but no flow when freezer door is closed. Temp drop in fridge side. Vent is cleared of ice build up.
Good day,
There are 2 vents. The one on the top to allow air from the freezer into the fridge. There is a second one, a return on the bottom left that allows the air to return to the freezer.
The return vent is the one that is blocked. (iced up).
On your model, it is very difficult to melt the ice out especially using heat due to all the plastic and foam.
Although ugly, it is best to unplug the machine, and leaving both doors open fo 24 hours.
Sep 22, 2010 | Whirlpool Refrigerators
Fridge & freezer are cooling on bottom but not
when you open the freezer door do you hear the fan blowing?sounds like the air isn't moving,there's also a damper on the fridge side,the door opens to let the cold air in and then closes,make sure the door is opening,you can take the cover off and put an ice cube on the twirled up metal part to close it and put your hand on it to open it to see if it's working
Mar 21, 2010 | Frigidaire FRS26H5AS Side by Side...
My freezer door pops open everytime i shut my refrigerator door
Good day,
First, make sure the gasket including the bottom is clean, as well as the mating surface of the machine itself.
The machine itself should be checked for being level. Side to side, if it's a top freezer model, the hinge side cannot be lower than the other side.
As well, front to back it should be leveled but with a slight tilt to the rear to assist in closing.
If none of this helps, then the magnets in the gasket itself have gotten weak and the gasket needs replaced.
Notes: Heavier items keeped in the freezer door will help to a degree. Closing the door slower as well.
The reason this happens, is that with the main door open, then closed, a large volume of air is forced into the fresh food compartment. There are vents that are open between the freezer section and fresh food compartment. This large volume of air when closing the main door is compressed into a smaller area, causing the problem.
Feb 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge side wont cool unless the freezer door is open
the little fan motor in the freezer is defective.  It may only be stuck.
Apr 01, 2009 | Whirlpool ED5VHGXM Side by Side...
How to reset water filter indicator on whirlpool american fridge freezer
Resetting your "change filter" light:
  • Press the light switch (the one that the refrigerator door presses every time you close the door) 5 times within 10 seconds. OR
  • If the fridge has a filter button, press and hold it for 5-10 seconds.
Mar 09, 2009 | Whirlpool ED5VHGXM Side by Side...
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Exterior Moisture
sounds like you have warm air getting into the machine, id check to make sure the doors are closing tightly around all sides with no gaps
Oct 26, 2008 | Whirlpool Refrigerators
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
