Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwasher won't drain
We just purchased a Bosh in August and the water won't drain. It is making an huming sound.
Thank you,
Debra REnn
  • Anonymous Apr 23, 2008
    Our dishwasher has been working well unilt tonight when my husband said he "might have used too much soap". It is notdraining and is making a lw, straining rumble. Any thoughts?
I had this problem too! I had connected the waste to a Ubend under the sink which has a side pipe for dishwashers or washing machines. What I didn't notice was that this piece wasn't open, you have to cut the end off!
The engineer was very nice about it when he came and found my mistake, he said it is a common problem!!!
Posted on Dec 29, 2007
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
I just bought a Bosh Ecosense dishwasher. I need to know size of the water supply line and drain hose?
The size of the water supply line is 3/8th inch (10mm)
The drain line is 7/8th inch (22mm)
Oct 10, 2011 | Bosch Dishwashers
My dishwasher didn't drain the water out on the end of the clicle? What could be the problem?
Hello, Thank You for using FixYa. I will be helping you today.I would start where your drain line connects to the house drain,This is where most blocked drains happen. Disconnect the drain line and put it in a bucket and try to drain the dishwasher. Chances are its blocked somewhere you just have to find it.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Microwave Ovens
Bosh dishwasher modle shu330cu not draining or lighting up
First...make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Jul 12, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Bosh dishwasher wont fill...also sink drains right intodiswasher.
sounds like your plumbing in your sink is going wrong way check pipes or your sink maybe have a clog in it
Nov 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Does not woork
Has the water drained by the time the dishwasher powers off?
The clicking sound is probably the (failed) pump motor and will require a service call or replacement of the unit.
Mar 27, 2009 | Maytag MDB9600A Jetclean II Built-in...
the tech that came out may have pinched the drain hose when he put the dishwasher back in place. disconect drain hose from under sink. put dishwasher in cancel/drain mode see if water is coming out at a trickle if so, hose is probably pinched behind dishwasher
Nov 19, 2007 | Dishwashers
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
237 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
