Question about Samsung S8300 Ultra Touch platinium-red Cell Phone
The resolution of my S8300 has changed in the last week. Had been out taking photos and noticed the change later that day. Screen is now pixelated, especially on black/grey areas.. A friend has suggested that im not getting enough "true black" coming thru hence the pixelation.. lighter images are ok. greyscale and black having major problems. please help!!!
  • 15 Answers
Try changing image quality when in camera mode settings
Posted on Oct 29, 2009
I install window 7 but my benq 15" lcd monitar's screen rosuation not competible. pls guide me how i increase the rosulation thnx
As for your 15" LCD BENQ Monitor, "1024 x 768" pixels is the Maximum Resolution
If you increase your screen higher than the Maximum resolution you get a black screen! because the monitor cannot support the resolution higher than "1024x768" pixels.
How to change your screen resolution Win 7-> Link
FYI
Here are typical resolutions for some popular screen sizes
19-inch screen (standard ratio): 1280 x 1024 pixels
20-inch screen (standard ratio): 1600 x 1200 pixels
22-inch screen (widescreen): 1680 x 1050 pixels
24-inch screen (widescreen): 1900 x 1200 pixels
Hope it helps.
Nov 22, 2010 | Computers & Internet
Haing taken photos on what was thought to be the 'large' setting the photos have come out only 72 pixels and I want to know if it's possible to change them into 300 pixels. or if not possible, how do I...
Set your camera to take pictures at the maximum megapixel level. Later, if you need to lower the resolution of your pics for whatever purpose, you can do that in any photo-editing program.
Aug 01, 2010 | Cannon Cameras
I have a dell with windows vista. the monitor is 20 or 21 inches wide screen. I recently had a friend try to install windows xp but at the last attempt he tried to reformat my computer & install it xp...
You can adjust the screen resolution to increase the size of the image to fill the screen.
Go to the Control Panel - Display - Settings and adjust the screen resolution to 1280 X 1200 pixels. If this still doesn't fill the screen then increase it further say 1600 X 1200 pixels even higher if necessary.
Aug 19, 2009 | Dell Computers & Internet
Videos are now a small picture and when expanded are POOR quality
It seems that you have reduced the resolution of the vedio capturing format. In format settings change it to maximum avaialbe resolution such as 1024x900, etc ( maximum among available). Also for increasing the still photo resolution, select the maximum mega pixel such as 3.2/5/etc.. Usually the mega pixels can be changed using any short cut keys.
Aug 11, 2009 | Canon PowerShot A470 Digital Camera
Dell Inspiron E1505 shows green pixels instead of black
the color pixels are different sections in the screen and the green section might be cracked
Apr 24, 2009 | Dell Inspiron E1505 Notebook
Changing Movie Recording Pixels
I phoned canon customer service. They said that you must turn the dial around the function set key. It will then change the movie mode from compact to standard ... and then you will be able to change the resolution. When I did it, the resolution went back to 640, which is the resolution on which I had it previously. Well before the compact mode issue.
Yannick Jeggels
Aug 02, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon 5D resolution question
The 5D has a 12.8 mega pixel sensor.
2 x 4 ft. is 24 x 48 inches, so you have to cover 1152 sq. inches using 12.5 million pixels.
Spreading 12.5 million pixels over 1152 sq. inches means 10,850 pixels per sq. inch. Taking the square root gives you a maximium resolution of 104 pixels per inch (or 'dpi')
Photoshop will allow you to increase the resolution by a process known as 'interpolation' .. increasing to 300 dpi using Photoshop before printing will give a better result.
NB. Depending on your printing process, you may end up dealing with files up to 500Mb in size ....
Mar 12, 2008 | Canon EOS-5D Digital Camera
Resolution
Many cameras will take pictures at only 72 dpi. Changing the resolution causes the camera to change the size of the picture in terms of pixel dimension (ie 800x600 vs 640x480) but always at 72 dots per inch. A photo editing program like Photoshop can change the resolution to whatever you need.
Dec 13, 2007 | Samsung Digimax 4010 Digital Camera
Minolta Dimage S414 Problem with resulution
What you are seeing is the difference between "pixel count resolution" and "embedded resolution". So in your example 2272*1704 is the actual pixel count resolution as recorded by the camera & 72 is the embedded resolution that tells the software (in this case photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it to 300 for printing. You can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions". This is a complex subject, I recommend looking at the following web page: http://www.fotofinish.com/resources/centers/photo/resolution.htm
Aug 08, 2007 | Konica Minolta DiMAGE S414 Digital Camera
Samsung S8300 Ultra Touch platinium-red Cell Phone Logo
104 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
