Question about Frigidaire ATF6000ES Front Load Washer
Error code 20 not emptying water on rinse cycle
    Genius:
  • Frigidaire Master
  • 1,461 Answers
Try clearing the pump
Posted on Sep 27, 2009
Error code f35
Too much detergent or wrong kind of detergent. If you use non HE detergent this will happen. You can remove the excess suds by running a cleaning cycle and adding cooking oil. The detergent will attatch itself to the oil and remove all soap residue, add an extra rinse to the cycle. Also run it empty.
Sep 02, 2014 | Maytag Washing Machines
What is E1 error code
The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
Jun 20, 2014 | Kenwood KDW243A Builtin Dishwasher
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
My zanussi washing machine keeps stopping during the rinse cycle with a flashing "error code 20". I have even tried to bypass the rinse cycle and put it on to spin or drain but it will not work. Help?
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating and positive testimonial is appreciated for answering your FREE question
Oct 07, 2010 | Washing Machines
1 1/2 year old lg WM2496H showed oe error code while washing a heavy unbalanced load. I removed the wet blanket (sitting in water) and tried drain/spin command with empty washer but washer will not go into...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!
Jun 09, 2010 | LG WM2496H Front Load
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
Washer stop in middle of rinse cycle
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Frig. Gallery washer and it will fill up and drain but not spin. What could be wrong and how can I fix it??
Dec 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
What is causing the drain pump to continue running
C1 - Partially Blocked Drain - This error will occur when dishwasher was unable to pump out water in less than 95 seconds. Check drain line for debris and blockage. If clear, check for a restricted drain valve in the pump. Check the pressure sensor for correct operation as it sounds like it may be defective and thinks that the machine is still full of water after it has emptied.
Oct 30, 2009 | Dishwashers
Frigidaire ATF6000ES Front Load Washer Logo
52 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
