Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Enigine quits when a let off the brake after starting.
  • jon_theisen Oct 01, 2009
    where is the brake safety switch located?
  • 472 Answers
It has a bad saftey swich may be the seat swich or its most likeley the brake swich
Posted on Oct 01, 2009
When driving my Why would my s10 just quit
sounds like a loose power connection or bad wiring in the engine compartment. Check battery cables and ground connections at both ends of wires and cables first. If the problem remains, test equipment and a wiring diagram would come in handy.
Jan 11, 2015 | 1998 Chevrolet S-10 Pickup
Why air conditioner cuts after three enigine cut on and off
cuts after three enigine cut on and off i cant understand that.
try 1 more time.
Jun 14, 2014 | 2002 Cadillac Deville
2003 xc90 will not start - code 063
have dealership check it out if you see anti theft security light flashing fault in the theft security will cause vechicle not to start. it will shut down fuel system.
Jul 20, 2013 | Volvo Cars & Trucks
How u fix code po303 passat 2001
i still have same code po303 i have change spark plugs and coil i add a ground wire i can resat end drive for 20+ milages no check enigine light
turn off start up runs for minute or so then coms back on check enigine light same po303 enigine runs very smoth no vibration what so ever I AM LOST
Feb 16, 2013 | 2001 Volkswagen Passat
C280 1999 Mercedes - enigine starts then stops a few times before starting
It is starter switch problem. Check starter switch, sometime due to excess carbon deposition, it looses contact.
Engine Performance Chip
Nov 23, 2012 | Mercedes-Benz C-Class Cars & Trucks
Enigine mounts tear/brake because vehicle is used on very rough terrain on a daily basis. What can I do to improve the engine mounts? jhbouwer@lantic.net
it not the small issue engine mounting is the very important part of the vehicle concern with mahindra dealership thay may post ur problem to the higher authourty of mahindra india
Dec 04, 2011 | 2011 Mahindra Scorpio
TRUCK RUNNING FINE THEN JUST QUITS. THEN STARTS BACK UP RUNS AWHILE THEN QUITS AGAIN
It might be the MAF sensor. I would try tapping on it while the vehicle is running to see if it will stall. Any check enigine light on?
Jun 10, 2010 | 2000 Chevrolet Silverado
I have a cpi formla r 50cc. I went to stop by letting the throttle go and braking, but the bike carried on going untill i bracked really hard. even tho the throttle was in its original place the enigine is...
Find where the throttle cable connects to the butterfly valve on your carb. Twist the throttle and see if the butterfly valve is sticking open. Your cable or the valve itself might be stuck, and needs lubed. The sell tools to shoot compressed oil into the throttle cable sleve, or start cleaning / oiling hte carb depending on what you determine is sticking.
Apr 18, 2009 | Gilera Saturno Bialbero Motorcycles
2000 Chevy Blazer Won't Start
You can check the manual that came with the Remote starter.
If you do not have one try look it up on line.
You can try call the people that install that kind of remote starter.
Some started do a lot more than start your car and the only way to know is to look at the manual.
You are trying to find out if it is has a ignition kill command.
Mar 16, 2009 | 2000 Chevrolet Blazer
Car stalls 2000 buick regal
check for short circuit , ground fault, ignition switch problem.
check wires on ignition for damage, burns from short. if car starts occasionally and gives problem it will get worse, not safe
Jun 07, 2008 | 2002 Buick Regal
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
60 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
