Question about Ryobi Garden
New tiller, used less than 4 hours. Won't start.
New tiller, used less than 4 hours. Was using it and it died and won't restart. Checked plug (dry) - doesn't appear to be getting gas to the engine. Bypassed kill switch but still won't start. Any ideas?
SOURCE: yard machine tiller won't stay started!
There is a small diaphram on the side of the carb that simply wears out. It's rubber coated mesh and the rubber coating breaks down and it stops pumping fuel into the carb. Sometimes you can run with the choke on partially, but it will burn 10 times the amount of fuel and cause more damage to the engine itself. I think it's about a $10.00 part.
Posted on Dec 08, 2008
  • 12 Answers
SOURCE: Mantis 2-stroke tiller won't start
This could be one of several problems...
• Last year's fuel. Get some fresh gas.
• Every 2-stroke needs a new spark plug each year... you know what that means.
• Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck.
• Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
Posted on Mar 21, 2009
SOURCE: Honda mini tiller stalls
Sounds to me like your main fuel jet is clogged if it will idle (different fuel supply) but not run with open throttle. When you open the throttle the engine gets more air and not enough fuel and quits.
Solution: Open (disassemble) the carburator and spray carburator cleaner through every orifice. Make sure you actually get cleaner THROUGH all holes. You've no doubt got fuel "varnish" in the jets from letting the equipment sit idle for long periods.
Prevention is the key: Always use a fuel stabilizer (Stabil) in your fuel. Mix as described on teh package for the "long term storage" concentration — generally double the dose of "normal" concentration and you'll minimize future problems.
Posted on Apr 09, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a Bolens BL410 cultivator that stops running
Hi and welcome to Fixya. The symptoms your describing are typical of what happens when the engine experiences fuel starvation.
It can be caused by a clogged fuel filter screen located at inside the attachment point of the fuel line manifold on the carb. Turn off the fuel and remove the mounting bolt for the fuel mainfold. Very carefully remove the plastic screen inside the manifold and clean off the debris that has built up on the screen.
If the screen was visibly clogged you probably have solved your problem. Just make sure you re-install the screen when re-connecting the fuel line manifold.
If the screen was not clogged then check your fuel lines for cracks. Air being introduced into the system will cause the same symptoms you describe.
If the problem persists then there is the possiblility that the needle and seat are partially blocked inside the carb itself on the bottom of the carb body after you remove the bowl. (Usually not the problem) However the bolt that holds the bowl on has 1 or 2 holes in it that can also clog and they must be clear.
And finally there is a BRASS jet that unscrews with a screwdriver in the bottom of the long draft tube (way below the throttle slider / needle) that gets clogged. Unscrew the brass jet and force air from the threaded end to clear the orifice.
By this time you probably figured out the float comes off with the bowl. note which side is UP! Also DO NOT adjust the float level it is preset. u|Unless you bent the float control arms it does not need adjusting.
Turn on the fuel... and start the unit after re-assy and it should run just fine. You should be tilling real soon!
Posted on Jan 29, 2010
Testimonial: "Good detailed feedback. I have been looking for air leaks in the fuel lines, but did not realize there was fuel filter for this engine. Thanks"
  • 3 Answers
SOURCE: My Honda mini tiller with a GX 31 engine starts
Clutch or transmission, a common problem with FG 100 series Honda.
Posted on Jun 05, 2010
My 5 hp craftsman tiller won't stay running changed gas sprayed carb new plug started it ran ok next day starts won't stay running dies fast like no fuel but can smell gas.
when it dies see if it will restart using a shot of starting spray in the air cleaner if it starts or sputters, sounds as if you have a plugged up carb you will need to dissasemble and soak in white vinegar for a few hours to un clogg (carefull with any gaskets)
if still nothing even with spray then you have a weak/defective coil or dammaged spark plug (start with plug replacement)
Aug 06, 2014 | Garden
Managemylife
Crank engine a few times. If spark plug is dry carb needs dismantling and cleaning. Probably gummed up.
Jul 10, 2014 | Craftsman 4-Cycle Mini Tiller
Tiller won t start
The fact that it started for any length of time, tells you the engine functions. The engine is STARVED of fuel mixture. Either the inside fuel line is clogged and needs to be blown out or the carbonator adjustment is incorrect. Check to see that the spark plug GAP is proper and when placed back into the engine it is hand tight with the spark plug wire formly in place.
Mar 01, 2014 | Husqvarna Garden
Tiller won't start. brand new
did you mix proper gas and oil. check or replace plug and check for spark
Apr 21, 2013 | Ardisam Inc Earthquake Mini Cultivator
There is oil on the spark plug in my new honda mini tiller (less than a month old). What might have caused this, and how do I fix it? Tiller won't start
Id say if its that new I would return it .Otherwise was it ever stored upside down or was it laying on its side
Its unlikely its a air filter issue with that low of use but you may want to check there to see if the oil is being siphoned up thru the breather line in the air cleaner area. lf the engine had been ran dry initially then there could have been damage done to the cylinder walls and the oil could be passing what is left to the piston rings,if this is the cause the unit would need to be overhauled .
Apr 19, 2013 | Honda 25cc 4-cycle Mini Tiller
Husqvarna ft900 won't start
did you open the choke all the way? also, what was the temperature when you attempted this at the onset? if it is cold outside, then set the tiller in the sun for at least a half hour then try starting.
May 30, 2012 | Husqvarna 12" Tiller Briggs 900 Series...
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
The engine doesn't start. I didn't use it for several years. It started and ran well for about an hour; when I shut it off, I could not restart. I have tried the obvious...new plug, putting started
You need to give the carburetor a good cleaning, as well as the air filter. Chances are the carb. will need a new carb. kit since it has been years since you last used it. If you need tips on how to clean the carb., just let me know.
Jim
May 30, 2009 | Mtd Garden
Garden Logo
209 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
