Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side, ice will not come thru the door dispenser. Water comes out just fine Please do not SPAM my email - this is my work email
  • 403 Answers
With these side by side ice makers there is a coil rod inside the ice tray. Somebody might pulled out some ice from the tray and it is not set straight. Try this, open the door and look to see if your ice has fused together. Break up the ice. Pull out the ice tray and look for ice blocking your coil. Look for ice blocking the route the ice travels. Replace the ice tray and make sure it sits in square and all the way back on the lips it sits on. Close the door and see if this works. Let me know if it does, if not let me know the model / number so I can provide you with more info.
JimmyC
Posted on Sep 27, 2009
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water dispenser stopped working. Water valve works
A major problem with the ge side by side refrigerators with metal liners is water freeze-up inside the door of the freezer. Short term repair is to heat the dispenser area CAREFULLY with a hair dryer right at the point where the water spout comes out.
The long term fix involves installing a heater in the dispenser part number wr49x10173 @$60. The kit comes with installation instructions..
Let me know if you have any questions!!
Aug 14, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Water dispenser is not working.
replace the filter.
if tht dosent work replace the water valve....
Apr 10, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Water is not dispensed but icemaker is working
It's more common to be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Sep 07, 2009 | GE GSL25JFPBS Side by Side Refrigerator
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Nov 25, 2008 | GE GSS25JEMWW Side by Side
GE Refrigerator PSS26SGPASS Will Not Dispense Ice or Water
Yes the power shopuld be there as well..One time i had the same issue and found a mouse had chewed partially thru the wire !!!! Trace it(wires) back down the bottom of the unit left side as it come out the bottom of the door and go towards the back to the board. see if you see a break in there
If you want the service manual post your email here i will send it to you
Jun 14, 2008 | Refrigerators
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
80 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
