Question about Hayward H Series Induced Draft Abg 100,000 Heater
Heater lights for about 4 to 5 sec. then gas shuts off,
I've jumped out all of the safetys and the same thing happens.
Hayward model H1001D
  • 990 Answers
You may have spider webs in the gas orfaces. Pull the tray and unscrew the orfaces from the gas manifold then clean with a toothpic or the like, These will be very small webs and are hard to see but they dirvert gas from the burner with the ignitor and when it does light the ignitor can't reconigse the flame and it will go out. i've seen this happen after the heater is off for the summer season and I've seen it happen ovet night. This iss one of the things you can avoide by cleaning and serviceing the heater once a year. i hope this was a help.Good luck
Posted on Oct 05, 2009
Hayward H 300 series pool heater for an inground pool. Pilot light is lit. Filter is clean. If I jump the terminals the heater will go on. If not the heater will not start.
I have an H300 Millivolt Hayward heater. It will start and run for about 1 minute then shuts off along with the pilot going out. I've tried cleaning all the terminals and running all new wiring but same result. I've also jumped out the TH to TH terminals leaving the jumper in place and it still shuts down after 1 minute. Any idea what that could be ?
Apr 24, 2011 | Hayward H-series Electronic Gas Pool...
Need to download a manual for Hayward H1001D pool heater
Hayward.com has owner's manuals available for download. It's about 30 pages long so make sure you have enough paper
Sep 21, 2009 | Hayward H Series
I have a H1001D pool heater that will not continue to stay hot. with heater turned on hi, fan comes on 20 sec.later temp. at vent is hot from the burning gas ,10 sec.later temp. is cool. fan continues...
One of the internal safeties are opening causing the main burner to shut down. Ensure you have proper water flow through the unit. It may be a high limit tripping and can be caused by several things, one being the limit is weak, second the heat exchanger may be partially plugged from scale. You may be able to determine the cause if your mechanically inclined, but I would recommend professional service.
Aug 03, 2009 | Hayward H Series
Hayward h250ed1 heater wont stay lit
Try cleaning your filter if dirty there will not be enough flow to llet heater fire. If filters clean you can try jumping the pressure switch.
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Trouble shooting Hayward pool furnace
Big enough propane tank? proper pressure reducing valve on the propane? Check both of those.
May 30, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pilot did not stay lit,replace gas valve , pilot stays lit,but now it won't fire up. Jumped the TH terminals and it shut off the pilot light.thermostat is set highier than the water temp.Jump all ths...
Your problem is the pilot generator where the flame is by the burners. This needs to be repalced. That is what is causing the pilot to go out and not start. It is a flame sensor and also tells the gas valve when to release more or less gas.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Induced Draft Abg 100,000 Heater Logo
552 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
