Question about KitchenAid KUDD01SSSS Compact Dishwasher
The width of the part that goes into the cabinet
I am looking at purchasing one. Do you know the width of the part of the dishwasher that goes into the cabinet? I have a 24" cabinet that I want to put this in.
4 Suggested Answers
  • 128 Answers
SOURCE: dishwasher for 32 inch cabinets
Miele makes a G600 series that are 32 1/4 " tall - that would probably be your best bet.
Posted on Jan 05, 2009
  • 246 Answers
SOURCE: I have a Fisher and Paykel drawer dishwasher and
hmmmm...the first thing that comes to mind is to check out ApplianceArt.com. they have alot of panel options. I'm not sure if they have the integrated ones you are looking for but they have cheap options for everything else.
Posted on Jan 07, 2011
  • 3247 Answers
SOURCE: I need the length, width height dimensions for a
if you cannot view this picture then go to kitchenaid site and type model number kuds02frss and select installation guide from the list. Please rate this solution if helpful or else post a comment.
Posted on Feb 25, 2011
What are the dimensions on a Kenmore 363.14192992 dishwasher?
Dishwashers that are installed into standard kitchen cabinets have a standard width and depth of 60 cm (Europe) or 24 inches (US), and most dishwashers must be installed into a hole a minimum of 86 cm (Europe) or 34 inches (US) tall. Portable dishwashers exist in 45 and 60 cm (Europe) 18 and 24 inch (US) widths, with casters and attached countertops. Dishwashers may come in standard or tall tub designs; standard tub dishwashers have a service kickplate beneath the dishwasher door that allows for simpler maintenance and installation, but tall tub dishwashers have approximately 20% more capacity and better sound dampening from having a continuous front door.
Feb 06, 2015 | Kenmore Dishwashers
How do you install a new drain hose on samsung dishwasher
It's a fairly big job. You have to pull the dishwasher out from under the cabinet. Then remove the left-hand metal panel. You should now be looking at the case-brake assembly. Reach inside the dishwahsher and turn the water-inlet bezel counter-clockwise to remove it. Now you can tilt out the case-brake assembly and loosen the clamp that holds the drain hose in place. Pull the hose off (have a towel or Sham-Wow ready to catch the water). Then you have to remove the clamp or hose-restraint at the back of the dishwasher. Thaen you can pull the drain hose out and replace it.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 12, 2014 | Samsung Dishwashers
What is width depth height specs
Good Morning Friend,
I see that you are looking for the width, depth, and height of the Frigidaire dishwasher, model# FDB636GF. The measurements are as follows:
Width: 23 7/8"
Depth: 24 1/4"
Height: 33 3/4"
Hope this is helpful.
-Best regards-
WP
May 28, 2014 | Frigidaire 24 in. FDB636GF Built-in...
I have a Fisher and Paykel drawer dishwasher and I'm wondering if there's a way to put a panel on it to make it look like and integrated dishwasher. It would need some way of the panel moving to start the...
Nov 19, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
What are the exact cabinet dimensions of a Roper dishwasher, model #RUD3000? Thank you!
The manufacturer specified cabinet dimensions for this model are:
Total width: 23 7/8" / 606mm
Total height: 33 7/8" / 860mm
Total depth (front to back): 24" / 610mm
If you need any further specifications for this model, please reply within this solution.
Regards,
BElectric
Nov 18, 2010 | Roper 24 in. RUD3000 Built-in Dishwasher
MDBH985AWS, I just purchased new-er dishwasher
if you want to see what it looks like you can see a diagram at sears parts direct .com . let me know if this info was helpful
Feb 25, 2010 | Maytag MDBH985AWB / MDBH985AWS 24 in....
How do i change a single 30 inch oven wall cabinet to a double
Measure the available cabinet space, height, width and depth. Shop out a unit that will fit or is close. The cabinet will probably need to be cut out and sometimes a drawer or doors may need to be eliminated. Check the amperage on the existing circuit at the electric panel to make sure it is sufficient to carry the new dbl oven. Every oven that I have installed coomes with a set of complete installation instructions
Nov 18, 2009 | Dishwashers
LG Dishwasher
I can't say for sure, but it is possible this unit is deeper than previous units. The only way to tell for sure is to measure the previous unit and compare to this one.
I would be suspect there may be something simple preventing the dishwasher from going all the way back into the cavity of the cabinets. Maybe the water line is in the way, the power plug, etc. are in the way. You would have to pull the dishwasher out and look it all over to determine if his comments are true or not.
Jan 23, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher for 32 inch cabinets
Jan 05, 2009 | Dishwashers
KitchenAid KUDD01SSSS Compact Dishwasher Logo
20 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
