Question about Lexmark P6250 All-In-One InkJet Photo Printer
Both my ink levels are the same but the colour does not print. And the page with help does not work. Is it compatible with my windows vista?
  • 138 Answers
Go to control panel settings,, and click on printer and there check the settings,, and make sure the tick is off where print black catridge only..
Posted on Sep 27, 2009
Tried to print something today after not using printer for about 3 weeks. First go all colours were present but streaky. Did the nozzle alignment but on testing found that Magenta was completely missi
Hi Mandy
1) confirm there is ink in the magenta cartridge first - by removing it from printer and looking through the ink 'window'.
If you can't see the ink level, it's either empty or very close to it. If so, replace the cartridge.
2) If ink level looks ok, install it back in printer then set out a full page of magenta (or red) background or large graphic and print few pages on high print quality setting until the magenta starts to print. This works better than printhead cleaning/deep cleaning because it wastes less ink.
3) If it still doesn't print red after 2-3 pages, the printhead is blocked. Take it out and rinse under hot water tap. Keep washing it until only clean water is coming out. Shake any water off then DRY the electrical contacts really well. Don't install a wet printhead back in printer - or you may damage it. Run one or two deep cleans and print a nozzle check. With bit of luck all colours will work now...
good luck!
Jan 13, 2015 | Canon Pixma iP3600 InkJet Photo Printer
Tip
HP 7660 Printer Ink Levels in Windows 7
I had tried all the tips and tricks, small driver downloads etc from the net, but still could not see my ink levels.
Tried the hold the Power/Cancel buttons trick, still no luck ...
The solution is obvious now :-)
Use the menu on the printer to print a test page, this is different from the one that software will print.
Amongst other things it will give you :
Black & Colour Cartridge Ink Levels.
Black & Colour Test Patterns.
Colour Bars.
Model Nos - Firmware etc.
I spent days looking for this and it was right infront of me.
(It's 5 pushes of the left Menu button to get to it)
Cheers.
on Sep 16, 2011 | HP PhotoSmart 7660 InkJet Printer
Epson t60 is good printer ?
Hi global_sreek,
EPSON is Super fast, affordable & powerful for all your professional photo printing needs.
Features
Increase your productivity with super-fast print speed
• Print instantly from your computer screen at a fast print speed of 12 seconds per 4R photo
Maximise savings with Epson INKdividual™ Cartridges
• Maximise savings and minimise wastage by replacing only what you need
• Epson 6 colour photo ink is highly affordable, keeping daily running costs low
Perfect printing onto CDs / DVDs
• Print directly onto the printable surface of your CDs/DVDs
Compact size to fit any space
• The Epson Stylus® Photo T60 is so compact, it takes up little precious studio space,
freeing it for other uses
Photo perfection with Epson Creativity Suite
• A powerful photo editing software that lets you perfect your photo prints with just one
click of a button
SPECIFICATIONS
Print:
Ink System - 6-colour
Ink Type - Photo Dye(??¥?œ¬??ž?®??š??¼??¸????₪œ?´¢ )
Max. Print Resolution - 5760x1440 dpi (with VSDT)
Min. Ink Droplet size - 1.5pl
Print SpeeD - Approx. 37ppm (Black) Approx. 38ppm (Colour)
Connectivity and Compatibility:
PC-less function - No
Index Sheet - No
Connectivity - Card Slot - No
Connectivity - USB Cable - Yes
Connectivity - Wireless - No
Interfaces - USB 2.0 Hi-Speed
OS Support - Windows 2000/XP/XP-x64 Edition/Vista Mac OS 10.3.9 or later with USB
Network - No
Adobe Postscript - No
Memory Card Backup - No
Ink Cartridges:
INKdividual - Yes
Ink Cartridge Model - 85N Ink Series (Standard Capacity)
Media:
Media Model - S041926E1; S041927E1; S041863; S041464E1; S041285; S042070; S041925; S041332; S041786, S041259
Paper Handling:
Max. Paper Size - A4
BorderFree - Yes
Max. Paper Capacity - 120 sheets
Roll Paper - No
Tractor Feed - No
Cartridge Model(s):
85N (Standard Capacity Black Ink) - Approx 540 pages (ISO/IEC 24711 and 24712 Test Suite)
Page Yield (pages):
85N (Standard Capacity Colour Ink)* - Approx 860 pages (ISO/IEC 24711 and 24712 Test Suite)
Hope it helps.
Thank You for using Fixya.
Sep 07, 2011 | Epson TM-T60 Printer
Printer only prints in black/white. have put new
It could be the print setting on your computer.
If you're using Windows, with your document open, go to File > Properties/Preferences. In the Print Setup tab, make sure to select "Print using all available ink" in the Ink Use section.
On Mac you can select Color in Print Setting in any expanded print dialog.
Sep 01, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Printer does not go
After few head cleaning, ink counter running low, so ink ligh (red) flashing. Then ink counter runing out, so the light stayed on. After replacing both of ink, red light stayed on, because the compatible ink (chip) not recognized by printer. Check epson status monitor. Use original ink or refill and reset ink level counter.
May 26, 2010 | Epson Stylus C60 InkJet Printer
Epson DX4850 problem getting ink levels to highlight using Vista
Checking the level of ink in an Epson printer can be done without having to remove the ink cartridges. This method works on black and white as well as color inkjet printers. Checking the level of ink can help you plan ahead when buying new cartridges
Instructions:
  • Install the Epson StatusMonitor software. This program comes on the CD included with the printer. It can also be downloaded from the Epson Web site. or from http://download.cnet.com/Epson-Status-Monitor-2/3000-2116_4-10024738.html
  • Open the Epson StatusMonitor program in any application (such as word processing, spreadsheets or Web browsers) that allows you to print. Click on the "File" menu tab in the control bar of the application
  • Select print or page setup from the "File" menu. A dialog box will open. In that box, click on the "StatusMonitor" icon, which will open the "Epson StatusMonitor" dialog box. Also, you can click on the "Utility" icon and then the "Epson StatusMonitor" button from the "Utility" dialog box.
  • Click on the "Update" button to update the display (if you do not think these levels are accurate) when the "Epson StatusMonitor" dialog box displays the relative ink levels for each cartridge in the printer.
  • Go back to the "Print" dialog box to change the way that the StatusMonitor utility monitors your printer and ink levels. Click on the "Utility" button again.
  • Click on the "Configuration" button in the "Utility" dialog box. The open "Configuration" dialog box will let you adjust settings such as ink level warnings and ink level monitoring before each printing.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Sep 16, 2009 | HP PSC 2210 All-In-One InkJet Printer
Internal test page fine, external prints black in blue
before you print, you have to check your options.
For example, if you want to print black and white, when you select PRINT from the menu, you click on PROPERTIES to the right side or bottom side, depending on which windows you use, then select grayscale/black and white, etc in the options that will follow to correctly use your ink, you can always REMOVE the ink from your printer as you only want to print black and white or non color pages.
I hope this helps you.
ManOwar
Jul 12, 2008 | HP DeskJet 845c Printer
Won't print
you should have a toolkit if the printer software is installed.
this should allow you to view printer preferences et,c.
Ink Levels. page sizes prefs. and general print options.
Try Start/Printer Or go into Control Panel/Printers Right click on your printer and select Properties.
Theres also a way, to lift the lid. press the Ink Button. And the cartridge should Move to the desired Low Cartridge Arrow.
Alternative is to print a test page, to see which colour is Missing.
Mike @ compurepair.
Jun 22, 2008 | Epson Stylus Photo R200 InkJet Printer
Status Monitor 3
In reply to SOLUTION #1 by Basti i have vista and have forced it to work with this status monitor 3 software i will post how i did it now.
First i downloaded the status 3 monitor so that i could fiddle with the programs and files inside from this link here
http://driverscollection.com/?file_id=24410
Ill skip right to the part on how to fix it you extract the file you just downloaded open the folder it went to right click E_SIINS2 with a bandaid icon goto properties then click compatibility at the top of the new window that opened check the box run this program in compatibility mode for: then in the drop down box below that windows xp (service pack 2) also i checked at the bottom run this program as an administrator and boom it worked i can see my ink and everything.
Jun 14, 2008 | Epson Stylus Photo R300 InkJet Printer
Lexmark z845 ink refill problem
i need adisk to install z645 printer towindows vista couputer
May 08, 2008 | Lexmark Z645 InkJet Photo Printer
Lexmark P6250 All-In-One InkJet Photo Printer Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
