Wash isn`t agatataing, seems to be sli^pping or going very slow aposed to way it should be
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Try the belt may be loose
Posted on Sep 27, 2009
I have 2 Asus 550ti top video cards that stop working after 8 hours
I would suspect that your power supply unit isn't up to reliably running a 2 card sli system...
May 24, 2012 | Computers & Internet
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
How many graphics cards can you run on this motherboard ? also whats the maximum ram you can install on it ?
You may install 2 x PCI-Express X 16 slot, supports two PCI-Express interface Graphics cards with SLI mode and 4x1Gb Dual channel DDR400/ 333/ 266 -184pin RAMs onto your AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI Chipset 2000MT/s FSB Dual Channel DDR400 Socket 939 ATX motherboard.
Check out your motherboard's specifications through this LINK.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 09, 2011 | AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI...
Whnever i play my d2 ex. insert disc is always pping out.and i lost the cd. wat shud i do??
go to www.btjunkie.com and download it from there.search for one with crack
Jun 04, 2010 | Diablo 2 Collector's Edition
Need m2n sli drivers..help?
Your SLI drivers as you mentioned were installed when your chipset drivers were installed. (NVIDIA nForce CK804 Chipset Driver).
If you use 1 PCI-E graphics card the bios will need to be adjusted to [Auto].
Using 2 PCI-E graphics cards you must install the EZ selector card correctly. See page 4-20 section 4.4 Adjust; SLI Configuration. Than see section 4.4.6 in your manual
Open the Asus link below if you need drivers for your M2N-E SLI;
http://www.asus.com/Search.aspx?SearchKey=M2N-E%20SLI
This may seem a bit tricky but its not. First time around the bios settings using SLI graphics cards will appears tough but you'll get it.
Cheers!
Mike
Oct 16, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I am turning the knobs on my scope to adjust it because it is shooting low and left. The knobs aren;t working it seems, because my problem isn;t going away. What is wrong with my scope?
O.K work slow, tap on the scope with a med-small screw driver handle -- JUST TAP IT, do not bang on it, easy tap easy tap with every adjustment, work slow, move opposites. .
Jun 25, 2009 | Simmons Optics
In my pc mercury 845 GLM AGP V5.0 mother board i will install vista but disaply driver do not match please solve my problem
your configuration seems to be low.... pls upgrade your machine and install windows vista or windows 7.... even if you install it successfully, you will have slow running probelms, low disk storage space and everything.... so use windows xp only...... pls vote if you like this solution...
Nov 14, 2008 | ASUS P5N-E SLI Motherboard
I have a asuse (A8N-SLI-DELUXE) with the nforce 4 sli chipset wont let me install any os.
Hi, have you also just doing the bios jumper reset. What make and model is the hard drive their maybe a diagostic to find out wht the problem is. Also does the pc beep at all when you 1st turn it on. Hope this has helped. Thanks
Onlinepc-Fix
lee
Mar 19, 2008 | ASUS A8N-SLI Motherboard
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
