Question about HP Photosmart C5180 All-In-One InkJet Printer
I have an HP c5180 printer. I repaired the encoding strip. Now I cannot seem to print in pink or magenta colors with regular printing. Interestingly enough, the pink/magenta does print if I run a "head realignment." Otherwise no pink/magenta with the "self test" print out or regular printing/scanning. Is there a software problem that can fix this or is the product "cooked"
  • 13 Answers
SOURCE: I have a HP Photosmart C5180 printer.
If your color improved slightly when running the printhead option then doing more should help get better results. Sometime the printheads get really dirty/clogged and running the cleaning option more then once is needed.
If you get a slight line running across the page (from left to right) usually the indicates dust build up on the printhead or ink carriage. The dust acts as a paint brush being dragged across your paper as the carriage moves across the page during printing. You can clean the bottom of the carriage with a Q-tip or purchase some cleaning paper for your printer.
Posted on Apr 19, 2009
pineworks
  • 4041 Answers
SOURCE: My HP C6180 is not printing its magenta color.
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 21, 2010
Testimonial: "Thanks for you good advice. It all made sense to me and it should have worked. I found 9 others reporting the exact same problem. Craig patentQ.com"
  • 217 Answers
SOURCE: My name is John HP 1015 MFP printer will not print Magenta.
This is caused by a dirty laser unit.
It is possible to clean the lenses and mirrors (with care not to scratch the surface silvered mirros AND not to disturb eany of the optical components)
There's quite a bit of dismantling to do to get to the laser unit, but if you work methodically (and remember to double check everything when you are 'rebuilding' the printer) it is certainly possible.
This is a common problem and also appens with HP Color Laserjet 1600, 2600, 2605, CM1017, and Canon LBP5000.
Posted on May 09, 2010
  • 217 Answers
SOURCE: We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
  • 104 Answers
SOURCE: magenta and pink don't print color well, have
Is your other color heads are working fine? Have you tried doing the printhead cleaning process. While giving print, just click properties in the page. Go to settings and you can continue with the software wise cleaning process. To do it manually, just visit this link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00491286&lc=en&cc=us&product=1101938&dlc=
Posted on Aug 02, 2010
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
My hp priter is printing pink lines in the edges of my paper
Your magenta toner cartridge or magenta print cartridge is leaking ...you should replace it (magenta is the red one).
Mar 23, 2014 | HP LaserJet Office Equipment & Supplies
Cannon MX870 prints everything pink
prints everything in pink or magenta. Cannot get it to print in regular black.
Dec 05, 2011 | Canon PIXMA MP780 All-In-One InkJet...
5100 HP Desktop printer--magenta ink comes out pink not red (right out of sealed package!)
magenta is just a fancy name for pink.... its usually a darker shade of pink not overly dark but not a bright pink that most associate with the color.
most hp printers use the ckmy color format as opposed to the rgb that most are used to. check your other ink levels to ensure that they are at least half full and when you print out a doc or pic requiring red, the other inks will assist in creating the proper shade
Mar 27, 2010 | HP Office Equipment & Supplies
CAN NOT PRINT COLOR -PRINTS PINK STRIPES
Take some paper towels, fold them in half, spray them with alcohol FREE glass cleaner and set your color cartrige on the paper towels and let them soak for thirty minutes or so. DO NOT USE ALCOHOL it sets the ink. also clean the thin plastic strip in the back of the print heads this is the encoder strip and it tells the print heads when to dispense if this is dirty from overspray it will affect your print quality. Use q tips and the same alcohol free window cleaner.
Jun 04, 2009 | HP Officejet 9110 All-In-One InkJet...
Printer prints all except one color
You need to clean the printer head with isopropyle alcohol
Nov 23, 2008 | Brother MFC 210C All-In-One InkJet Printer
Pages are all PINK!
The problem is the magenta developer assembly.
This is one of the 4 color assemblies you see when you remove the imaging drum.
The part number for the Magenta Developer is "Magenta Developer (M6090)"
This is a very involved repair, and although i have actually instructed other how to change the part, it is only something you should attempt if you are somewhat mechanically inclined.
If you do get the part and wish to change it yourself, I can forward you the detailed instructions on how to remove and replace it.
Thanks,
Oct 23, 2008 | Dell 5100cn Laser Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
